securityguy
Do the rails that are a part of the Bed Utility Group interfere with the install of any tonneau covers? Thanks!
No typically on a lot covers the tonneau cover frame rails slides into the channel on the rails.Do the rails that are a part of the Bed Utility Group interfere with the install of any tonneau covers? Thanks!
Thanks...not sure I am following you. I want to put my current Retrax cover into a bed with the Utility Group and want to make sure that the claps that hold down the cover don't interfere with the utility group rails. Sorry for being dense on the subject.No typically on a lot covers the tonneau cover frame rails slides into the channel on the rails.
Thanks, I understand that I need those new brackets to get my cover to work.I have the BUG and the MFT. The issue was with the MFT brackets at the front corners of the bed. No issue with the tie down rails. Access original soft roll up cover.
Here's a pic., that may help( may not be for your exact cover)Thanks...not sure I am following you. I want to put my current Retrax cover into a bed with the Utility Group and want to make sure that the claps that hold down the cover don't interfere with the utility group rails. Sorry for being dense on the subject.
Understood. I just don't know if the rails will interfere with the clamps or the install of the retractable cover box that sits inside the bed.Not sure. My truck came with those brackets because of the multi function tailgate. Not the bed utility group. The supposedly are to offset the torque from the swing function of the tailgate doors.
I don't have the RAM BOX set-upHere's a pic., that may help( may not be for your exact cover)
Yes i have it, no issues with bug-rails.Thanks...anyone with a Retrax and the Bed Utility Group?
Ordering my brackets today so I can get my Retrax installed next weekend.Yes i have it, no issues with bug-rails.
My bigger question is why did @Snicklefritz_76 think he didn't need them? Those brackets are there for a torsional reason and, if you take them off, you must replace them with somethingI don't think you'll need these brackets, according to Snicklefritz_76 ...
tonneau covers that work with the multifunction tailgate?
Anyone have a truxedo Sentry with the brackets? I want to get a soft roll up cover with the replacement brackets and have been eyeing that cover for a while Same question here for the Tyger soft roll up?.. Anyone install with the aftermarket Brackets? Sent from my iPhone using Tapatalk5thgenrams.com
First off, I need to give props to the guys at Right On Brackets. I ordered a set of brackets before I had my truck or my tonneau cover which I ended up not needing. I contacted ROB customer support and they let me ship the brackets back for a full refund. Truly excellent customer service. I hope to do business with them in the future.
Maybe those that have RAM BOXES don't need and the rest of us do? If the RAM BOX beds have brackets for the MFT like the non-MFT trucks, you would think they are needed regardless.Good morning. I have the Retrax 80244 (2020 RAM Limited + BUG + MFT + RAM Boxes) BUT have not yet installed the tonneau cover yet. I'm awaiting some warmer weather here in mid-Michigan ... maybe APR or MAY 2021??? But as I understood @Snicklefritz_76, he did not need to remove any OEM brackets, in order to install the Retrax 60244. I certainly may have been mistaken and will not know myself until I'm slapping my cover on.
Good luck!
My bigger question is why did @Snicklefritz_76 think he didn't need them? Those brackets are there for a torsional reason and, if you take them off, you must replace them with somethingUnless he has a Ph.D. in Physics, and ran an analysis showing the RAM engineers were wrong, for $90, I think I'll install them to be safe. Small price to pay IMPO.
As I said above, if the trucks with RAM BOXES do NOT have these brackets, as do the trucks without, then you would be correct. Just getting clarification as you never stated, that I read anyway, that RAM BOX trucks with the MFT don't come with support bracketsPhD not required, only common sense. The brackets mentioned per this thread are replacement brackets. I have the RamBox package along with the MFT so my truck did not come with any brackets, hence no brackets to remove and no brackets to replace. Why would adding a tonneau cover require drilling holes and mounting additional brackets?
This is a simple ask/question. Moving forward, if you need clarity on something try asking without being such a d!ck!
