Adding Adaptive Cruise Control
vincentw56
will do. I’m determined to get it working at this point.
Maybe someone here might be able to help... right now I have a EPB warning light I can’t get rid of. The DTC is C2212: ECU in plant mode. I can’t figure out how to get rid of it. I’ve tried about everything I can in alpha with no luck. This came on after replacing the abs module and HCU. The EPB still works fine.
Any update on this? I wouldn't mind adding it to my truck too.
tdb0021
Denver, CO
yes, and no. I had to take the truck in for an abs initialization because I couldn’t get rid of the parking brake warning light. I actually talked with the tech there and he’s interested in my project and is willing to help. Unfortunately I’ve been swamped with work lately as we are closing out a project. I haven’t had much time to play with alpha since the initialization.
tdb0021
Denver, CO
So i've managed to get the DTC in the cruise control module down to "C2206 - vehicle configuration mismatch"
I assume this means i haven't selected the correct settings in the BCM. I'm hoping it's just a matter of getting the correct configuration. I am trying to gather more vehicle configurations so i can compare them to mine. If anyone reading has ACC, Lane assist, etc and could send their vehicle configuration that'd be huge. If anyone has any insight it is much appreciated.
Current status in the DASM is as follows:
ECU Qualification:
RLS: Not set
AHBM: Not set
HUM: Set
COM: Set
UAM: Set
Theft Deterrent Present: No
Power Locks Present: Yes
Ambient Lighting Present: No
Approach Lamps Present: No
Side Repeaters Present: No
UGDO Theft Disable Present: No
RKE Present: No
Front Fog Lights Present: No
Tip Start Present: No
Remote Start Present: No
Reprogramming Attempt Counter:
Number of Reprogramming Attempts - Block 1: 0
Max. Number of Reprogramming Attempts: Block 1: 1000
Number of Reprogramming Attempts - Block 2: 0
Max. Number of Reprogramming Attempts: Block 2: 1000
In-Plant Status: Not active
Sensor Has Been Aligned: Yes
Response on Event - light activation state: Activated
Ignition Voltage: 12.40
Blindness Counter: 119
Bussed Inputs:
System Voltage: 12.40 V
Averaged Ambient Temperature: -40.00 Deg.C
Vehicle speed: 0.00 km/h
Ignition Switch Status: RUN Position
PRND Status from Trans: Park
Cruise Control Cancel Switch: Not set
ACC Distance Decrease Switch: Not set
SCM Cruise Control Set/Accel Sw: Not set
SCM Cruise Control Coast/Set/Decel Sw: Not set
Cruise Control Resume Switch: Not set
SCM Cruise Control Implausible: Not set
SCM Cruise Control On/Off Sw: Not set
SCM ACC On/Off Sw: Not set
SCM ACC Distance Increase Sw: Not set
ACC Can Be Enabled per ESP: Set
Trans in Limp Home Mode: Not set
Motor ACC is OK: Yes
Brake ACC is OK: No
Electronic Park Brake: Open
tdb0021
Denver, CO
Went to my dealer and was able to sit down with a tech and go through the modules with him on witech. I'm getting 2 faults that are preventing the ACC and Lane departure from working. U148A in the steering "implausible data received from DASM" and C2206 in the DASM "vehicle configuration mismatch". Interestingly, when i disable 'vehicle config 7 - lane depart present' The U148A code disappears.
I was able to get a current vehicle configuration profile to compare to mine. I have changed every setting in the BCM that seems remotely relevant to ACC and Lane Depart to what his was and i am still getting the same codes. At this point i'm convinced i'm missing a module, but i can't seem to figure out what module i need to add or swap. I suppose it's possible the DASM i have is VIN locked (it is a used module) as i know some modules are (such as an ABS module). But i haven't found any information to suggest this yet.
Jimmy07
Honorary Site Supporter
I forgot about this thread. Can I get a copy of your current bcm configuration, and I’ll take a look and see if anything stands out?
Jimmy07
One important setting I see is VehConfig 8 steering C factor needs to be set to TYPE 2
Set CustSetMenu 1 Forward Collision Mitigation Braking CSM Present to NO
Set P/T Chassis Net EPB Electronic Parking Brake to ENABLE
Connect as a 2020 DT body computer in advanced mode and make sure these two are set to NO:
VehConfig 7 Lane Centering / HAS feature present
VehConfig 7 LDW without haptic feedback feature present
tdb0021
Denver, CO
when I try to connect to 2020 in advanced mode on windows it forces a connection to DT2019 Var 3
Jimmy07
Do those last two VehConfig 7 settings show up in the list in that variant?
Jimmy07
Also, I should have said connect to your bcm first, then switch to advanced mode and select 2020 DT out of the list. Then click advanced diagnostics.
tdb0021
Denver, CO
Negative I do no see the last two configuration options in the variant 3.
After changing those other options though I am still left with the same vehicle configuration mismatch dtc
Checking other modules now
Jimmy07
Try this to get those two settings- connect as normal. Switch to advanced mode. Select 2019 DT Var 4. Don’t click connect again, but click active diagnostics. They should be in that list.
U148A is gone now, though?
tdb0021
Denver, CO
Try this to get those two settings- connect as normal. Switch to advanced mode. Select 2019 DT Var 4. Don’t click connect again, but click advanced mode. They should be in that list.
okay this worked and can confirm those vehicle config 7 options are set to No by default.
U148A is still showing after clearing
U0104 in the TCM appeared but clears and stays cleared.
tdb0021
Denver, CO
Okay so I just checked the status in the DASM and I now have more parameters showing.
Something that’s interesting is the module is showing that this module is VIN locked.
It’s also reading FCW Error.
I wonder if you cannot use a used DASM.
Jimmy07
Does it show the donor VIN as being current AND original?
tdb0021
Denver, CO
VIN - Current: 1C6RREHT8KN847709
VIN - Original: 1C6RREHT8KN847709
ECU Part Number: 68320950AL
Hardware number: 68320948AL
Hardware Supplier Identification: Delphi
Software Logical Block Supplier Identification: Delphi
My Vin is not these
I think we just found our problem.
Jimmy07
My Vin is 1C6SRFMTXKN500444
Possibly. You’ve been riding around with the DASM installed for a while, right? It would have picked up on your VIN by now. That would be odd that a module like that would have to be a virgin...
tdb0021
Denver, CO
Yes, I’ve had this plugged in for over two months. I know for a fact it’s from a wrecked limited. I’m not sure why this particular module would have to be virgin either. Seems strange, but possible?
Here is my current status in the DASM:
ECU Qualification:
RLS: Not set
AHBM: Not set
HUM: Set
COM: Set
UAM: Set
RKE Present: No
VIN Locked: Yes
Ignition Voltage: 11.90
FCW Selection: Fcw Near
Blindness Counter: 158
Bussed Outputs:
ACC Set Speed KPH: 0 km/h
ACC Set Speed MPH: 0 MPH
Requested Gear, Upper Limit: 0
HMI Screens: None
Forward collision warning error: FCW Error
Forward collision warning setting: Yes
ACC HMI Screen request: Yes
ACC On/Off Status: Off
Small graphic display: ACC Ready TG1
ACC stop commanded: No
ACC drive off commanded: No
Engine torque request maximum: No
ACC cruise control enabled: No
ACC engaged: No
Status Information DASM: No
Status Information DASM: No fault
Disable fuel shutoff: Yes
Brake jerk request: No
Brakes Pre-Fill Request: No
Assistance system display request (priority): No request
DAS request ID: No assistance system is braking
Forward collision warning status: Not active
Bussed Inputs:
System Voltage: 11.90 V
Engine Torque Enable Request AS: Enabled
