Dmalonecentral
 - Aug 19, 2018
TLDR; After dealer visit my Adaptive Cruise isn’t working with the error in the title. Anyone else have issues?
Took my truck to the dealer to finish some “We Owe” stuff and do a couple TSB’s.
Work Done:
Installed Power Side Steps and flashed sales code.
Installed Trailer Brake Controller
TSB for HK Volume
TSB for sudden brake assist when in reverse
Asked them to inspect Lane Sense to see if camera can be recalibrated after lift as it does not work as well as before the lift.
Alignment
Somewhere in there (Lane Sense would be my guess) they have completely disabled the Adaptive Cruise Control and the Forward Collision Warning. Shortly after the truck starts I get the two orange icons in the picture below that appear to show them as disabled. If I attempt to turn on FCW in the UConnect settings it checks the box and after about 2 seconds beeps at me and unchecked it. If I attempt to turn on ACC while driving I get the message “ACC/FCW Unavailable Service Required”.
They are aware of the issue and have ordered a new “module”. They said it would take a week to get the part and then they would need to keep it for a week so they can drive it everyday to program it. They already put over 80 miles on my truck in the 2 days it was there.
Outside of letting them do their thing I just wanted to reach out to see if others have had issues with either ACC or FCW and how it was remedied because it seems to be a grasping at straws situation going on at my dealership and ACC was the single most important must have when I purchased this truck.
For a little more backstory, this is my second 19. I traded in a Limited to go to the Laramie because I had all kinds of problems with the 12 inch screen and finally just had enough. I hope this is an easy fix and will be behind me in 2 weeks time but I envision a scenario where this drags on and I ultimately get sick of this truck too. Which would be unfortunate because this is the first vehicle I have had where I went all out to get it to how I wanted it to be.
Oh, and as you can see in the picture on my drive home from the dealership I received an error to service the Tire Pressure System as one of the wheels just completely fell off the map. This came back after a battery pull and a couple of starts and a trip around the block.
Work Done:
TSB for HK Volume
Alignment
