Loss/lockout insurance?I guess this is considered a accessorie ha
Key card says to drop in mailbox if found, then post office mails it back to youLoss/lockout insurance?
From what I read, You put them in mailbox if found, or there's a number on the back you call and there's a reward for turning them in.Loss/lockout insurance?
I installed Train Horns on Ram Vader!
Since I changed my tires to a larger size, the factory spare tire was worthless to me. I wanted to see if I could install and on board air system with a 5 gallon air tank and VERY LOUD and large Train Horns in that space without removing the heat shields. I went with the Kleinn Problaster HK9 - 150 psi System with the demon 730 train horn kit. I also decided to upgrade to the ultra blastmaster valve upgrade. The blastmaster valve upgrade gives each horn its own solenoid with a half inch airline to each horn making them even LOUDER. I figured what the hell, go big or go home! I love the saying on the box that the train horns came in. It states “ Too loud? Too bad! “Holy ****, these horns shake the ground. They are so LOUD! The instructions stated not to mount the air compressor upside down due to overheating. So off to Lowe’s I went and bought some metal and brackets and made my own mounts for everything. I am not a welder so I went with the bolt on method. I used nylon locknuts everywhere so nothing should come loose due to vibration
I spliced into the factory horn wire. I wired The air compressor pressure switch and Train Horn solenoids into my trigger 4 Plus 30 amp switch # 1. That way I can turn them on or off as needed. I still have just the factory horn when the trigger switch # 1 is off. I also ran the air filter for the compressor into the driver side ram box. It worked out perfectly because there are grommets at the bottom of the ram boxes. I just removed the grommet and ran the quarter inch airline and screwed on the air filter. Now the air compressor will have clean dry air all the time.
What is the point of this? Just to scare people? I feel like if you just like the sound you'd have to drive like an ******* to use your horn enough to justify it. I drive in a medium sized city and use my horn like once every few months.Here you go!
I couldn’t get my drivers side lined up right so I went to a muffler shop and they got me straight by putting some heat to itI looked at the crooked magnaflow exhaust.
I believe magnaflow has an issue on this product regarding driver side tail pipe for 19429.
I guess I don't see a scenario in which the regular horn wouldn't do the same job. Normally I'd say if you like it then it's your money but this is one of a few things that can annoy or scare other people and maybe not even the ones cutting you off.To each their own. I rarely use the Horn also but it gets stupid drivers attention when they cut into my lane or doing stupid crap like texting and driving and causing problems. I’m not one of those idiots that just drives around and honks the horn at people just to scare them.
My fault. Carry on.When did this thread become about debating air horns and not about what you did to your Ram today?
Hey everyone, I am a proud new owner of a 2020 RAM 1500 Laramie and I am looking to add nerf bars to my truck. I have been looking at the Ionic 5" black curved nerf bars but I am still undecided. Does anyone already these installed? Any recommendations?
Went up to Rollins Pass, above alpine, at about 12k ft. Learned about about an old railroad built in 1905 that ran over this pass and still with a lot of remnants of it. Tested the Mopar lift / suspension and new Wildpeak tires. Was an absolute joy and can’t wait for more of these adventures! Sad to see so many fires in our state (last pic is one of a few burning right now), especially from up here. Come on snow!
View attachment 72045View attachment 72046
