Le_Slacker
Just dropped this off for tint
Update in 4 or so hours !
![9e78f17f2d3027bd66e2b066b83428ba.jpg](/community/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20201016%2F9e78f17f2d3027bd66e2b066b83428ba.jpg&hash=8bdb0d479e3a4cd635cb662400ed109b)
That is a great color.
Those look sooo good! I just picked up Laramie with the sport appearance pack but these just look better. I can never tell exactly from the picture but are all the emblems (RAM, 4x4) flat black or are they a very dark gray?Just dropped this off for tint
PRO-TRUCK DAMPER 2019 RAM 1500 FT
Eibach engineers, manufactures, and sells the highest quality performance aftermarket suspension products in the world.eibach.com
Just ordered a pair of those for my truck.
I'd assume they're just like the Bilsteins and you don't need to go over a certain height. That's how I'm treating mine.Are there any limitations to watch notch you can use with these? I have the ORP.
Awesome looking truck!!Picked up my new 2021 Laramie Quad-cab EcoDiesel tonight. Such a sexy beast. Now its time to get her rugged. Looove the drive, so smooth. Traded in my 2017 Rebel and this definitely is the best upgrade.
I did the same thing including the windshield and the sunroof panels, makes a huge difference on the heat allowed in. Hopefully it will protect my dash tooAnd done
Didn’t want it too dark and was mostly in it for the ceramic
35% all around, including sunroof
70% windshield
Driving in full sun (obviously all closed up) and can already feel how much better this will be !
Where did you order from? Part number?
I searched on Amazon and found them.Where did you order from? Part number?
Remind me not to get behind you!I installed Train Horns on Ram Vader!
Since I changed my tires to a larger size, the factory spare tire was worthless to me. I wanted to see if I could install and on board air system with a 5 gallon air tank and VERY LOUD and large Train Horns in that space without removing the heat shields. I went with the Kleinn Problaster HK9 - 150 psi System with the demon 730 train horn kit. I also decided to upgrade to the ultra blastmaster valve upgrade. The blastmaster valve upgrade gives each horn its own solenoid with a half inch airline to each horn making them even LOUDER. I figured what the hell, go big or go home! I love the saying on the box that the train horns came in. It states “ Too loud? Too bad! “Holy ****, these horns shake the ground. They are so LOUD! The instructions stated not to mount the air compressor upside down due to overheating. So off to Lowe’s I went and bought some metal and brackets and made my own mounts for everything. I am not a welder so I went with the bolt on method. I used nylon locknuts everywhere so nothing should come loose due to vibration
I spliced into the factory horn wire. I wired The air compressor pressure switch and Train Horn solenoids into my trigger 4 Plus 30 amp switch # 1. That way I can turn them on or off as needed. I still have just the factory horn when the trigger switch # 1 is off. I also ran the air filter for the compressor into the driver side ram box. It worked out perfectly because there are grommets at the bottom of the ram boxes. I just removed the grommet and ran the quarter inch airline and screwed on the air filter. Now the air compressor will have clean dry air all the time.
ES ENGINEERED BY SCHILDMEIER... https://www.amazon.com/dp/B07NBVL2JB?ref=ppx_pop_mob_ap_shareWhere did you order from? Part number?
