Clicking sound coming from the brake pedal when braking?
Agustinacosta
Hi, I have an annoying clicking sound when braking, sounds like a relay or something like it, I have one week with the truck but I’m pretty sure it wasn’t there. Can you help me to see if you have this too?
2019 Limited
Douglas31
2019 Limited
I have the same thing going on. Noticed after about 3-4 weeks of driving. Haven’t had a chance to get the dealer to look at it.
RamCares
Michigan
2019 Limited
I have the same issue with mine.
Hello All,
Please keep us updated on this concern going forward. If you decide to schedule an appointment with your dealer, we can provide an additional layer of assistance while in service. Just send us a PM.
Lamar
RAM Social Care Specialist
2019Bhorn
I'm having a issue like that, but it sounds like it's coming from my driver's seat, been doing it for a month, once you hear it, you can't unhear it, it's like a ticking clock, drives me crazy
768mph
Adjust your pedals back and forth. It may have settled on a bad spot.
You think that’s weird but has fixed mine. From my 19 and my 16 Ram Sport.
Douglas31
I tried that the other day with no luck.
Schultz8100
Has anyone found a cause or fix for this yet? I just picked up a new bighorn which does this and is extremely annoying.
M
Mdegen93
Guest
*Update*
Clicking sound went away on its own and I haven’t heard it for about two weeks now
James Cole
Hello guys...
I have this too on my truck, do you guys know where to apply the grease?
mike_ct
I noticed mine, there are 3 relays that click in the module behind the knee panel. depends on how much pressure is applied. it is annoying.
Feltcycle
My truck is making this clicking noise now. It sounds like a sticking limit switch or a noisy relay. Has anyone found a solution? I don’t think grease on the pedal assembly is the solution to my noise.
M
Mdegen93
Guest
I didn’t think so either. I sprayed some grease on the assembly and it went away in a few days of it being worked in. Dealer could also do it for you
ac1dd
Light grease won't last even if it works for a short time....best bet is to use a moly based heavy duty grease that could be applied with a
pencil style brush.
