Clicking sound coming from the brake pedal when braking?
Agustinacosta
Hi, I have an annoying clicking sound when braking, sounds like a relay or something like it, I have one week with the truck but I’m pretty sure it wasn’t there. Can you help me to see if you have this too?
2019 Limited
2019 Limited
I have the same thing going on. Noticed after about 3-4 weeks of driving. Haven’t had a chance to get the dealer to look at it.
2019 Limited
I have the same issue with mine.
Hello All,
Please keep us updated on this concern going forward. If you decide to schedule an appointment with your dealer, we can provide an additional layer of assistance while in service. Just send us a PM.
Lamar
RAM Social Care Specialist
I'm having a issue like that, but it sounds like it's coming from my driver's seat, been doing it for a month, once you hear it, you can't unhear it, it's like a ticking clock, drives me crazy
Adjust your pedals back and forth. It may have settled on a bad spot.
You think that’s weird but has fixed mine. From my 19 and my 16 Ram Sport.
I tried that the other day with no luck.
Has anyone found a cause or fix for this yet? I just picked up a new bighorn which does this and is extremely annoying.
I posted this video in another thread related to a creaking sound. There is a lot of slop in the brake mechanism because its made of three different stamped metal pieces and held together by compression clips and it makes all kinds of noise, and once you hear it you can't unhear it.
https://player.vimeo.com/video/293442149
*Update*
Clicking sound went away on its own and I haven’t heard it for about two weeks now
Hello guys...
I have this too on my truck, do you guys know where to apply the grease?
I noticed mine, there are 3 relays that click in the module behind the knee panel. depends on how much pressure is applied. it is annoying.
My truck is making this clicking noise now. It sounds like a sticking limit switch or a noisy relay. Has anyone found a solution? I don’t think grease on the pedal assembly is the solution to my noise.
I didn’t think so either. I sprayed some grease on the assembly and it went away in a few days of it being worked in. Dealer could also do it for you
Anyone else try grease spray fix? If not, any other fix?
Light grease won't last even if it works for a short time....best bet is to use a moly based heavy duty grease that could be applied with a
pencil style brush.
