Garage 1 / Ram 0. Looks like I have some buffing to do...☹️ What's the easiest method to fix this? It is all clear coat.20200919_133325.jpg20200919_133316.jpg
Installed my Bilstein 5100s on setting 5. And had the shop flip the tires so the white letters are facing in while it was there.
Installed the Readylift 2” level kit with UCAs. Went pretty well. Tried to do it without pulling the axle nut and the CV joint popped out. So had to go to 3 stores to find a 36mm socket. Once I had that it took about a hour to do the second side and button everything up.
I’ll let it sit for a week and see if the front settles a bit. May end up with a 1” spacer in the rear.
Ordered new wheels as well. Should get those mounted next weekend.
AE0C8AF0-4027-40F9-B40B-916F8BD1A82D.jpeg1A6153B5-FBDA-40EB-85DF-B016923F40A9.jpegA8CF6F21-5423-4C17-9DE9-C5734C29E5C2.jpeg31666492-2BDB-4F03-B4D0-F64C828CEDF7.jpeg
Went and got a little dirty today. Tested out the 4wd system for the first time and played with hill descent. Works pretty good. (y)
Got my 10,000 mile service so it was time to stop hiding my Pedal Commander and find a mounting spot.
I ran the wire behind the cover below the steering column.
Also did a test mount for my light bar. I mounted it inside the grille guard.
How is the performance? How easy was install? Was looking at same intake on Amazon.
Haven't tested it out yet (as far as the performance). The install was easy. I even had my 9 year old son to assist. For the looks, I give it a 10. I should know more tomorrow... More to follow!
How’s the ride quality compared to stock?
What was done for your 10,000 mile service?
The recommended service at no cost was:
- Rotate tires
- Change engine oil and engine oil filter
- Inspect battery and clean and tighten terminals as required
- Inspect brake pads, shoes, rotors, drums, hoses and park brake
- Inspect CV/Universal joints
- Inspect engine cooling system protection and hoses
- Inspect exhaust system
I had them also do a wheel balance.
