BowDown
He was using HP tuners yes.
But thinking about it logically; if you want to move at 60 mph in 8th gear, you need to make a certain amount of HP/torque to do so. You need fuel and air to make HP. I don't see how you can maintain HP while reducing fuel. His claim that you're just swapping fuel from one cylinder to another makes sense, as then the engine is still making the same amount of HP, it's just "robbing peter to pay paul".
If you reduce fuel, you reduce HP, it's a pretty simple equation to me but I'm not an engineer of that sort. Perhaps there are some light effiencies gained by only firing in 4 cylinders instead of 8, but it certainly can't be exactly half; ie, entering MDS MUST be increasing fuel to the other 4 cylinders that are still active; perhaps it doesn't double what it was before activating, but I"m sure it goes up. Only extensive testing or Ram engineers would be able to determine how much extra fuel is pumped into those 4 cylinders once MDS starts.
And I've mentioned more than once how high I've gotten with MDS completely disabled. I cannot believe I would get higher than 25 mpg even when using MDS. Whatever MDS is doing, it's like in the fractions somewhere, next to nothing.
True but you dont need 8 cylinders to make 60HP. You can easily maintain 50-110 HP with 4 cylinders, the whole premise behind MDS/DOD.
Example, the 5.7 running at 15-2000 RPM (65 mph in 8th) probably makes around 150-180 HP. Does the truck need to make 150 HP to maintain 60MPH? No. Drop 4 cylinders, drop HP but not below whats needed to maintain 65 mph. There will a be small increases in fuel to the other 4 cylinders but that's all as long as the speed is constant.
Now, the question Is is it half? I dont think, I'd suspect that its closer to 15-25% reduction in fuel consumption.
What you are doing is reducing parasitic loss power created by the engine ingesting and exhausting air by those cylinders not not firing, that's where the biggest savings likely occur, the fuel savings may be 20%
