Pics when you’re done!
It would be great to see what oversize tires people are putting on the new 2019s with stock or off-road suspension. I am guessing 33s will fit without issue (275/60R20), particularly with the off-road package, but it would be great to know for sure, and to see if anyone has gone bigger.
Do you have pictures? I want a 2" strut spacer level with 305/55r20 with 20x10 -18 and would love to have it not rub! Pictures of angles and stance and all that goods so I can decide! 90% highway miles here.It will rub with stock suspension. With a level you should be fine. I’m running 20x10 -25 with no issues.
Cv angles are nearly flat. Rides good. I’ve got a Readylift top hat spacer and control arms. It didn’t change the ride at all. The increased stiffness only came after I installed the new tires.Do you have pictures? I want a 2" strut spacer level with 305/55r20 with 20x10 -18 and would love to have it not rub! Pictures of angles and stance and all that goods so I can decide! 90% highway miles here.
Awesome! Thanks for the pictures. Maybe the -18 will make it not rub then. If it's just pushing the front of the inner fender back a bit that's not too bad. I want to avoid cutting at all cost!Cv angles are nearly flat. Rides good. I’ve got a Readylift top hat spacer and control arms. It didn’t change the ride at all. The increased stiffness only came after I installed the new tires.
I do have a very slight rub in the front of the front wheel wells. When in full lock over bumps or in reverse it runs the plastic liner. Easily fixed. Just need to heat the liner up and push it out a hair.
-18 might buy you just enough to clear it. Each truck is slightly different as well. Others have not rubbed with the same setup. Either way, all that would be required is heating up the plastic liner with a heat gun and pushing it out. No cutting required.Awesome! Thanks for the pictures. Maybe the -18 will make it not rub then. If it's just pushing the front of the inner fender back a bit that's not too bad. I want to avoid cutting at all cost!
I put a pair of 33x12.50r20s on a pair of Asanti Off-road Cleavers. They look great but the tire is the same size as the stock ones I took off the guy at the tire shop said if I went to 35s I would have to do some sort of lift. I was wondering if anybody knows this to be true.It would be great to see what oversize tires people are putting on the new 2019s with stock or off-road suspension. I am guessing 33s will fit without issue (275/60R20), particularly with the off-road package, but it would be great to know for sure, and to see if anyone has gone bigger.
285/75R18 (34.8" x 11.5") Cooper Discoverer AT3 XLT on Fuel 18 x 9 1.
No rub, excellent ride, no cabin noise difference noticed.
Bighorn with ORP and 3.92s.
Planning to swap the Mopar side steps that were already dealer installed for Go Rhino Domininator D6. If anyone in Toronto area interested in Mopars...View attachment 28815View attachment 28816View attachment 28818View attachment 28819View attachment 28823
Your truck looks great, I'm looking to got to the same size tire or a 295/70 18 . How much did this affect your speedometer and transmission shift points, and what did you do to correct it if anything?I ended up going with the 285/75/18 on the stock rims for now with a 2.5" motofab leveling kit.View attachment 38923
Thanks. It didn't change things too much I did notice the truck was a little sluggish with the heavier tires but it did not kill my MPG. I switched out the stock rims for some method race wheels and i'm happy with how it feels now. I used one of the Tazer DT to correct for the bigger tires.Your truck looks great, I'm looking to got to the same size tire or a 295/70 18 . How much did this affect your speedometer and transmission shift points, and what did you do to correct it if anything?
thanks
That is sick... I'm trading in my Tundra for this bad boy next week. I am STOKED.........
