Biggest Tires on Stock 4x4 Suspension
Charlez79
It will rub with stock suspension. With a level you should be fine. I’m running 20x10 -25 with no issues.
Do you think a -12 would still rub? I know I’ve seen some people post on custom offsets that they’ve gone up to 33x12.5 with -25 without rubbing on stock 4x4 height but wanted to ask here if anyone’s tried it. Thanks man!
ksn240
It would be close. There seems to be a little bit of variance in these trucks. If it rubs it will be minimal and easily fixed.
Birdman_2000
I flipped through all the pages on this thread and didn't catch anyone with Offroad package without air. Mine came with 275/55/r20, anyone know the tallest you can go on the stock rims without rubbing? I would assume 285/60/R20's would fit, but it's been years since i have looked at bumping up tire size.
cnnr_thomp
Los Angeles
I just got mine back from the dealership after having wheels/tires installed. I’m running a 2019 Limited; Air Suspension; Off-Road Group/Package (adds extra 1” lift); long bed, and had Fuel Vapors (20x9 +20 offset) with Nitto Ridge Grapplers 35x11.50. Zero rubbing at full lock, zero cutting. After searching this site, reviewing multiple threads, I’m confident that this is the largest tire (20”wheel) you’ll fit on a limited with air suspension. Had I not added the off-road package, they would have rubbed. Less than 1/2” clearance at full lock. View attachment 25401
So these pictures are normal ride height correct? You’re not in OR1?
gHiDoRa
Elvis Presley
Same here, would like to know too.
Swimchamp8107
Kee
Kee
Thx for feedback. I do like your agressive looking tires with the stock wheels.
Huskymush
Wheels: 18x9 0 offset
Spacers: 1.25" in the front 1.5" in the rear
Tires: 305/65r18
Fitment is great. Only rub in entry/exit on full lock.
Decided to run spacers to even out the wheels with the Bushwhacker fender flares. Would have done a custom offset but got the wheels before the flares. 20190531_220619.jpg 20190505_160517.jpg 20190505_160601.jpg
LadderCo2
Dealer by me is installing the MOPAR 2" Fox lift on their trucks. They are installing Nitto 35x11.5.20's on stock BigHorn wheels.
Wakesnowb
I want to keep my 18" rims and put some BFG KO2s on them. Anyone know what the biggest size will fit with the stock suspension and no level? The BFG KO2s have the following sizes:
33x12.50R18/E 118S
34x12.50R18/E 121R
35x12.50R18/E 123R
LT255/55R18/D 109/105R
LT255/70R18/D 117/114S
LT265/60R18/E 119/116S
LT265/65R18/E 122/119R
LT265/70R18/E 124/121R
LT275/65R18/E 123/120R
LT275/70R18/E 125/122R
LT285/60R18/D 118/115S
LT285/65R18/E 125/122R
LT305/65R18/E 124/121R
LT305/70R18/E 126/123R
LT325/65R18/E 127/124R
I am looking for the largest size with no rubbing. Anyone know what size will work best?
In2h2o
PorBoy
Millville NJ
If you find a “ narrow “ tire then possibly. I’ve seen several folks run them but all have had some time of rubbing at some point. Several have said that it is acceptable and does not bother them in the least if that helps any. :)
