I have the thermal axle and there's an electric valve that splits the incoming coolant to go to the heater core and to the rear diff. It looks like flow to the rear diff is secondary to the heater core, but if the valve to the heater core is not closing all the way then this could be part of the issue. I found one article on this system but it doesn't state if there's isn't demand for heat then the heater core valve will shut. The assumption is it would close otherwise why have the valve, but it could just tee off the heater line and only open/close for the diff. It looks like it's part "Coolant 3 Way Valve - Mopar (68309834AC)". My AC is running at 50 deg. 2020 Laramie Ecodiesel
I could clamp above the valve but are there any thoughts on this or how it's supposed to work?
Trucks Take the Heat | MOTOR
www.motor.com
Did the clamps yesterday absolutely works! aprox 20% improvement In AC performance, Shame having to do this to a $60K new truck!
Any side effect to clamping down the hose?
Omg that sounds great. Please post pics and whats the size of the hose.Not that has been reported and none that I know of. I am getting ready to order T-valve to put in there so not have to "clamp" hose.
Side effects: 40-47 degree vent air as opposed to 55-57 degree vent air
If you look earlier in the thread, there are pics and hose sizes.
5/8"
Unless I'm mistaken on my definition of a T-valve.
Where I am from, wat I/we would call it. Posted pic of 1 possible alternative, which is valve and all I ordered. Also posted pic of clamp method (Harbor Freight Line Clamp) for a temp fix till I get ordered parts to put in line.
Yup! I used the Murray climate control one referenced earlier in this thread, rather than the one you show here, but they both do the same thing. The ball valve one you have there is probably a better made unit.
Great cant wait to get to it . It get 112 hereIf you look earlier in the thread, there are pics and hose sizes.
5/8"
That valve was at a 1/2 inch. The stock hose is what a 5/8thIf you go with a PEX route like turkeybird did, the valve will be a different size, as he showed.
Screw all you guys who said "only lost an ounce or two of fluid"! Did this to mine yesterday, and there was quite a bit of coolant in the lines, even with the one from the heater core clamped temporarily!
Not serious about the first sentence above.But seriously, it lost a little bit of fluid, I'd say at least a few ounces or more. May add a little bit to my reserve tank to make up for it.
Ive installed the valve on two separate 5th gen rams now. The trick to not losing any coolant is to clamp the hose that goes the heater core, then attach your new piece of hose to the new valve with clamp tight around valve and clamp loose around water pump tube end of hose and make sure valve is closed. Yank the hose off the water pump tube and quickly slip the valve with hose on the tube. If done this way you can prevent much leakage. Do not do this when the engine is hot or warm!
Any pics of the process and a parts used would be greatly appreciatedIve installed the valve on two separate 5th gen rams now. The trick to not losing any coolant is to clamp the hose that goes the heater core, then attach your new piece of hose to the new valve with clamp tight around valve and clamp loose around water pump tube end of hose and make sure valve is closed. Yank the hose off the water pump tube and quickly slip the valve with hose on the tube. If done this way you can prevent much leakage. Do not do this when the engine is hot or warm!
