Mine was 836 out the door . No issues w install except I drilled out bed liner for drain hoses
Do you have a link to the website? been looking for one 969 + tax every website I checked. " FOUND IT $ 839.99 TAX INCLUDED + FREE SHIPPING
Have the folks here today doing a full detail on my Ram and the Corolla just in case.
I’ll probably put it on tomorrow. I’m trying to decide if I want to leave it off to cure some more as I can’t get PPF on it for at least a couple of weeks.
I would leave it off to have the film put on.
Finally installed my ham radio. Yaesu FT-8800R
Mounted inside the console on the back wall. Drilled a hole in the floor to run all the cables - power, antenna, remote head.
mounted the remote head in front of the CD player. Was able to fish the remote head cable between the CD player and dash. Only wire I couldn’t hide well (by the seat) was the antenna bc it’s so thick and got lazy to remove more bolts and carpeting.
I ran the antenna from the bed into the cab using the rear plug under the back seats.
Nice, I have same radio and I am still trying to configure my set up. KF5YZK By the way how did you set your antenna
Added a NOCO port plug to the rear bumper for the block heater, just gives it a cleaner look than having a plug hanging out your hood scratching your paint in the winters.
Curious why you chose to run through the rear bumper.
Also, what route did you take to the rear bumper and what did you use for hardware
