do oyu happen to know what the clearance is form the groud to the bottom of the board... i had some tubular running boards and i bent the brackets doing some off roading.... wondering if i switch it up how much clearance ill gain.
Installed Lamin-X yellow fog light covers today. I have always used them, but thanks to @Waterfowler41 I saved a few bucks!
No remove. Just wet the light and the cover and slide it on. 10-15 minute install. Lamin-X gives you a precut cover.You obviously removed the fog to apply? How bad was it to get out?
A FYI in case the caps are aluminum.My “BIGGEST” Mod so far.
Ok...so I exaggerated a little.
It’s in the small details.
A
Valve stem caps - beware of aluminum
Purchased a second hand set of 20" Laramie wheels for my Bighorn. The tires came with aluminum valve stem covers. Didn't put any thought into the valve stems at the time. Today I went to check the air pressure and "galvanic reaction" had set in. Not a good moment. I managed to get them off...5thgenrams.com
Nice! I should have the yellow film and gunsmoke head/tail light films arriving today! Any real world install feedback or tips?
Big thanks to @Waterfowler41 as well for the 20% off!
Where do you pickup Rapid Tac from? Lowes? Home Depot?Got a few messages from people so here’s the link without having to go through the hassle of watching my video (although the views are super appreciated).
It’s 20% off anything at Lamin-X. Doesn’t necessarily need to be Ram specific parts. Enjoy!
Promo code for 15% off all products at Lamin-x Protective Films
Get your exclusive discount at Lamin-x. I think you'll like it!go.referralcandy.com
For those of you installing them, post pics here! Would love to see the before and afters!
i ordered mine from walmart.comWhere do you pickup Rapid Tac from? Lowes? Home Depot?
p.s. following now for all the great vids.
Does the RapidTac make the film slick to apply? I just used water, which is what Lamin-X stated and worked fine. The film is sticky and it took a few tries to get it into place, but it worked. I'm waiting for the little bit of water to evaporate now.Rapid TAC II Application Fluid for Vinyl Wraps Decals Stickers 4oz Sprayer https://www.amazon.com/dp/B006RMEFNS/ref=cm_sw_r_cp_api_i_fZDbFb6QNJWVN
Thanks for all the posts, vid's and discounts, Waterfowler41! But sadly, it appears that Lamin-X does not make these films/covers for the Limited or Longhorn models. So I'll search for alternate amber films.Got a few messages from people so here’s the link without having to go through the hassle of watching my video (although the views are super appreciated).
So you guys all seem to really like the yellow fogs. Any reason in particular you prefer them? Just curious cause I've always seen them on "ricers" locally and have never tried them myself.
