TheSwollenOne
- Jul 7, 2020
do you have an accurate number to the amount of gains with this? for some reason I cant find it.Best performance upgrade that I have done on the truck to date.
At one time I saw a claim of 30 HP, but I cannot find that link now.do you have an accurate number to the amount of gains with this? for some reason I cant find it.
I do not believe a dyno is going to give you an accurate assessment of the Ram Airflow.Did a pretty comprehensive review plus dyno a while back. I have no regrets and really like it but you’re not getting close to 30hp. At some point I am going to run a Jay Greene tune and that should help but our cars use torque curve. So any increased airflow gets adjust at the engine to get back in-line with that curve. Helps a little, sounds great, i noticed helpful mpg gains...but the car will not allow you to get 30hp, just won’t.
Mopar’s “Ram Airflow” Cold-Air Intake System For Ram 1500:
Lol I’m sure they are more concerned with meeting that “ bonus “ standard but I really could be wrong. :) I'm not sure what a "bonus standard" is... but I know that engineers provide design solutions that meet requirements, cost and schedule.5thgenrams.com
Technically you begin to see boost on a 6000 RPM motor that produces 350 HP, which is pressure being put or packed back in to the manifold, at around 50 MPH. The pressure created here is small but it is exponential, meaning it will rise by the square of the speed that you are traveling and will depend on the ram air systems design as to its efficiency at each given speed and the RPM's of the motor.Your truck will have to be moving over 200 MPH to see anything over 1 PSI of forced induction. Believe whatever you want, but physics and math don't lie.
Sooo close. It's actually for legality, because in a few states the aftermarket and cold air intakes are illegal due to emissions testing like... *cough* California* *cough*My guess is that this is because it's not EPA-certified/tested, so FCA is just covering its bases. But that's just a guess.
∆ This. I wouldn't say 200mph but definitely over 100mph. Thats why a new intake can't possibly add torque on it's own because there's 0 forced induction. But they can add mpg and better throttle response.Your truck will have to be moving over 200 MPH to see anything over 1 PSI of forced induction. Believe whatever you want, but physics and math don't lie.
I was not aware until now that this truck did not have a MAF Sensor.I don't drive @ 100mph unless I'm on a track, I have a dedicated car for that.
Did you know you do not have a MAF meter on your truck? It is speed density tuned and utilizes the Manifold Absolute Pressure Sensor, Ambient Air Temp Sensor, Oxygen Sensors, Cam/Crank position sensors (RPM), and data tables for input to determine stoich. A/F ratio.
Also one other consideration is the Delta of the new Ram intake compared to deficiencies of the current stock intake which is restrictive and the added carbon filter also adds to the restriction . Both of these adds static at 350 cfm . My calculations for the Ram intake at 70 miles a hour 6000 feet per minute with the less restrictions , no carbon , equals about 6” water gauge gain . The faster the speed rpm the higher the gains . Not to mention higher density colder air . Compared to one PSI which is 27” w.g. . So all these factors helps with horse power gains on the ram air type of intakes . I have another post with all my calculations but I don’t know how to quote here yet .
Just case in point the standard OEM intake has a chock section measured at 2” x 5” at 350 CFM Intake volume at highway speed the velocity is 6000 feet per minute which is significant back pressure equates. The 2”x5” is just under 3.5” round at that velocity it’s about 12” w.g water gauge per 100 feet of duct . If you look at the stock intake you have several 90 degree turns equals 25’ each straight pipe also those flex section adds static . My estimate would be about 50’ of straight smooth pipe is 6” w.g. of static on the stock intake . So if you take The Ram air unit it removes all the chock sections and hose so you negate the static but the air velocity at 70 miles a hour is 6000 feet per minute you therefore reduce the static by 6” but gain about the same 6” w.g. This is significant .See picture below of the chock section Hard to see but the top of the intake on stock Ram 1500 Hemi on bottom of this picture . I typically do calculations on dust and vacuum systems in air ,pollution control. The way you test it is with Dyno but I can see the gains . Thing about the horse power it takes at vacuum pressure at 350 cfm . Just case in point just finished 1000 cfm vacuum system for small amusement park in Anaheim Ca they required 100 horse power . So 350 cfm at slightly lower velocity may equal the horse power gains for that efficiency as quoted . I think that is the reasons that CAIs work and also this rams especially with the higher density cold air help these engines . I have no idea why Ram would design such a chock on the intake makes sense on back pressure on exhaust for lower rpm around town driving. Just my two cents. If I mis calculated anything let me know .
