Air Ride with DAYSTAR and REVEL Links!
Checkmate251
Got Daystar level and Revel links front and rear done today! Gained about 2” all around! 34BB08CF-5285-4619-B3CC-2B6399DF698F.jpeg
Chippy
That looks great. I have a Rebel and Revel states on their website the rear links do not work with them? (Rebels) I’m ready to pull the trigger on the spacers and links for front but like a raked look. Can I use the rear links and get the rear up a little more to maintain some rake. I have searched just getting no real answers or a can’t find them.
could someone maybe let me know about these Rebels with air in particular thank you in advance.
Checkmate251
Yes the rear links work just fine, not sure why it states that they do not in the Revel page, I even called them and they said they work. I could probably do a little higher in rear just don’t want to max out shocks, I got about 2” all the way around!
Chippy
You just made my day buddy thank you!
Ellisstrong
Atlanta Ga area
Did it make the rear end bouncy like it does the front?
RamFarmer
On the revel links...when you guys says 60MM how are you measuring? Center to center of link hole?
RamFarmer
Ok guys on the 2020 Ram 1500 Limited with the off road package, what's the most you guys have been lifting the front? I've went an inch so far with no errors. Revel factory was suggesting the ORP will only go up 3/4"
Checkmate251
I got just over 2.5” with no error codes or control arm hitting issues, I used the Daystar pucks also!
DDUCK22
I have the Daystar shims in front and the Revel links on my Limited with air suspension. I put on Fuel 20x9 +1 wheels and 33” ridge grapplers.
i couldnt be happier. Somehow the truck drives better. Maybe a tiny bit stiffer but still a really nice ride. These tires are only slightly louder than stock. The truck handles better in turns.
Thanks to all the previous forum members that did the heavy lifting on this.
I know this is an old thread but I hope you can help. I have a 2019 non off-road package (orp). I have 5 modes. I spoke with revel and they said if I only use the spacers and links the front will be higher than the back.
Do you have the orp and did this happen to you after installation?
Thank you in advance
clazer
Get the full set of links, front and back. Then you can raise the rear a smidge if needed. Not sure why revel would say that. The ride height of the truck is solely controlled by the links. Spacers just affect the stiffness of the Springs to get to said height.
DDUCK22
Thank you for the info. I will take your advice
Checkmate251
ORP truck and I used both front and rear links, with Revel pucks! Front was high until rear links installed. 8B26A44A-30EC-41D3-9B37-AF1E4FA7CACA.jpeg
Checkmate251
What size tires?
295 60 20 Nitto Ridge Grappler! Just under a 35x12 tire!
I was told that 295 65 20 would rub!
These are CLOSE, but only rubbed once backing up full lock! Fill the wheel wells perfect I think!
20x10 -12 wheels
ThatThingGotaHemi
North Carolina
Looking to do spacers and links to clear a small tire rub.. I have a 20 Limited with ORP with 305/65/18s.
Just wanted to check back again that nobody was throwing errors or having any computer issues w/ the Air?
