ny2az
There's no such thing as a dumb question ... I have a 2020 Ram Limited and would like to join the Hellwig (Rear) Sway Bar Club. Do I also need the Hellwig Adjustable End Links (P/N = 7961) for my model/trim? Or simply order the Rear Sway Bar (P/N = 7709)?
THANKS in advance!
just the #7709 ... stock truck only requires the basic hellwig with stock end links used ... if lifted or lowered ... you would then require a set of adjustable links to maintain a level sway bar...
