There's no such thing as a dumb question ... I have a 2020 Ram Limited and would like to join the Hellwig (Rear) Sway Bar Club. Do I also need the Hellwig Adjustable End Links (P/N = 7961) for my model/trim? Or simply order the Rear Sway Bar (P/N = 7709)?
THANKS in advance!
just the #7709 ... stock truck only requires the basic hellwig with stock end links used ... if lifted or lowered ... you would then require a set of adjustable links to maintain a level sway bar...
New video up on my channel walking through the installation of the Roadmaster Sway Bar.
Out of curiosity I also weighed the factory bar and the Roadmaster kit. Any guesses as to how much more the Roadmaster bar weighed?
I have no guess at the weight differential, but one question. Given the large Hellwig contingency in this forum, what made you choose the Roadmaster over the praises of Hellwig?
BTW, great install video and information. Thank you. When I get to installing a sway bar, I will be reviewing your video again.
THANKS so much ny2az! I'll be placing an order today. Take care and be safe.
No body can park by me then.
Heat coating finally got finished on the headers so I put those on yesterday. Just a little bigger than the factory exhaust manifolds
View attachment 59378View attachment 59379
Finally got my front bumper plugs put in, as well as the rear license plate cover put on. Running boards should be here next week.
Plugs clean up the front well. Watch with the rear plate cover, some peeps on here had plate frames from the dealership and it was rubbing the tailgate when it was fully open (not much clearance) and scratching the paint off the tailgate, just something to check.
Ummmm 23lbs?? Just kidding 14lbs ;)
Great video.
Added blue led accent lights behind the grill. Wired to the fuse box to come on any time the truck is running.
That looks great! I'm trying to do something similar. What fuse did you use and how did you run the wires to avoid the active grill shudders?
So I did a little thing.....installed the front today. Will finish up the rear tomorrow. And to answer the big question a lot of us were asking.....yes, the BDS 4" kit for the 2019 1500 with air suspension WILL fit the 2020 Limited Eco-diesel. No problem.
Where do you have your wideband installed at?
Thanks! I’ve heard great things about Roadmaster sway bars in the RV groups and I like to try out new brands so figured this was a good opportunity.
Also, my channel is at the cusp of breaking 1,000 subs. There’s not much in the way of Roadmaster reviews so figured pioneering it might help put me over the 1k threshold.
Thanks for the comment! Appreciate the views and hope my videos help!
  • Staff online
