Talpa
It was extremely easy. Got a led kit from amazon. Replacement filter from autozone
Nibis
Installed PAC AMP PRO, RCA patch cable, Remote Wire, 4 Gauge Power Wire & Ground. Also installed the bass knob for the Amp Pro. My wife was in the truck and seen the knob and asked what it did, she thought it was factory, LOL. I guess I did a good job.
Well today, i had to pull it all apart, I lost volume. I checked the Pac and it was acting like it was working. The led was lighting up as i worked the volume knob. I tried to reset with the SWC, no luck. Repeated all connections and got sound back. Going to be more than a little mad if this happens again.
O Captain My Captian
What fuse ports did you tie that into? Why did you choose those ports?
I used F33 for the always on connection. It controls the overhead console buttons. Nothing that is mission critical to the overall running of the truck.
The other fuse was the accessory switch.
It was recommended by BlackVue to connect to both. Why? I honestly don’t know, but I’ve seen other install videos having done it.
I have a more detailed description of what I did here.
cruzinj
Did you plastic dip the chrome?
BlckDT
Metro Detroit
Did you consider a Pedal Commander and decide against it for the Sprint Booster?
Yes. The PC would be just as good, but Sprint Booster has been around for a very long time and they have won awards. Also, I liked the small button control and pedal lock mode.
STOKED
How much did that run you?
Sent from my HD1905 using Tapatalk
I was quoted $250. I BS'd with the guy the whole time and when he was done he said $200, but I gave him $240.
LaxDfns15
Memphis, TN
FINALLY GOT MY REAR SUSPENSION HEIGHTS TO BE EQUAL! No more 3/4" lean to the driver side! Now I can install my Timber Grove airbags that I've been sitting on trying to get this lean fixed.
Ramtrx
How did you fix the lean?
LaxDfns15
Memphis, TN
Detailed it here:
SilverNight2020
Southern Illinois
Had some fun this morning upgrading the door speakers. Dash speakers on the way. Decided to join the Infinity Reference crew, and boy am I glad I did. Such a night and day difference. If anyone is contemplating the upgrade, do it, you won't be sorry. I have the base 6 speaker system just for reference. No feedback when driving with and without MDS engaged and did not switch the pins for these connectors like many have had to. Crutchfield for everything.
Solosnavy
Irvine, CA
i see alot of guys replacing their speakers... are any of you doing this that already have the harmon kardon system?
Wakesnowb
Was thinking about this with my Harmon setup but I think it sounds good enough. A better equalizer would do wonders probably. I would also like to put some polyfill in the subwoofer box to improve the bass sound there.
