Headers and a Cam?
Tell me more...... any pics? I’m curious on how belt set up went
It’s a stage 2 system with its own dedicated belt.
sc with e torque???? wow. how is driveability?
That's for the part only. Install would be on top. A simple turbo kit is no more that $2500 if you go the Ebay route which thousands are doing incl. myself and make stupid power. Install is relatively easy if you're mechanically inclined. A complete supercharger kit is $6500 plus tune plus install. I'd suggest anyone interested in more power save up and go forced induction at this point.
still need a tune with turbo. if anything turbos are more complicated to install in my opinion, and then there is turbo lag, difficult to tune properly as a daily driver, etc.
It drives just the same as before. I still have auto start stop and mds on and all. I plan on getting custom tuning on it but just haven’t yet.
Gave me about 115 more horsepower to the wheels.
stock tune and no codes? that is crazy. be careful you dont run your engine too lean and burn out valves, melt pistons, etc.
You guys make me wish I hadn't bought the 7 year/unlimited miles Chrysler warranty. OTOH - keeps me from dinging my wallet...
Still jealous. But I DO have a 11PSI Rotrex Blower in my Slingshot - getting ready to do Cams. 350RWHP/17,000 lbs. THAT is HP:Weight...
Rick
If you get your ECM unlocked I suggest going through HP Tuners. HP Tuners will just unlock it. Diablo unlocks it then re-locks(so to speak) it so only they can tune it. Or so I've read.
I had HP Tuners unlock the ECM and I've been having an issue where the ECM locks up and gives me a 'no bus' error. Everything slowly stops communicating (suspension, transfer case, ABS, etc) and then the motor finally shuts down on the highway. Can't restart either as the push start button is disabled. Need to wait for the time-out period to happen (which is the time you have set in the radio to keep the ignition on after leaving the vehicle). Heard the boot loader HP Tuners is using on the 2019+ Rams may not be good or compatible with the body control module, and causes it to lock up around 20-30 mins of run time. At least that is what's happening to me.
Just FYI. But I agree - HP Tuners is the industry standard and what almost all tuners use. Just need to get over this hump for the 2019+ Rams.
Ouch that sucks! Best I can find out is they have to phyiscally modify something inside the ECM to unlock it. Maybe you just got a booger-ed one. Everone is very top secret about how to unlock ECM's. Guess there's just too much money in doing it. I swear the DOD can't keep a secret this well...
Hopefully HP Tuners will make this right!
I’ve been running my diablo unlocked ecm with procharger flawlessly for 13k miles now and about 10 months
ok what i am still interested in is what cam and supporting mods will work in this truck?!
^^^^^ Question is what your end goal and use of the truck to you? Different goals will result in different cams which result in different supporting mods.....
Is it going to be DD, going to boost at some point?
Personally, if I were to do it I would look for a little more power and some extra revs at the top end. Preferably one with minimal to no Droning. Id like for it to sound as stock as possible. Really am looking for power. I don't really like the sound of the Pro chargers I prefer the sound of a Whipple or an eldebrock.
