Black Badging - How to ?
Thanks for the reply.
What about the RAM lettering on the grille any tips on removing them?
If you don't want to keep the chrome letters, then you can just pry them out but the tabs holding them in will break off.
If you want to keep the letters, then you would need to remove the entire grill so you can get behind the letters to disengage the tabs.
This is a pic of the section of the grill that the letters are mounted on. It is hollow on the inside but you have to remove it from the main grill.
Is it possible to remove that front center section while the grille is still on the truck?
If not I'm going to gentry pry off the letters since they are going to be replaced anyway.
Thanks for the pics.
I got all my Black emblems and RAM letters installed today...yeah!
Removal tip: Warm up the grille letter with a heat gun first then take something with a sharp edge (like a gasket scraper)
and catch the lower corner of the letter then quickly flip it towards the front. I managed to get the letters removed without breaking any tabs.
The RAMs head on the tailgate has allot of adhesive seemed more difficult to remove than the one on my 2016 RAM.
Heat the emblem then use fishing line to slice through the adhesive then peel off the adhesive.
Sure would be nice if it were an option when ordering!
John
Here is a list of part numbers for the blacks parts I was able to find;
Tailgate Ram Head - 68276327AA
5.7 Hood Emblems (not sport hood) - 68276336AA / 68309877AA
Front Grille "RAM" lettering - 68298470AA
"RAM" front door emblems - 68309785AB
"Laramie" tailgate emblem - 68282678AB
"4x4" tailgate emblem - 68276325AD
Black exhaust tips - 68284731AA
Still looking for the tailgate handle. Hope this helps anyone looking to black out their emblems.
Finished it tonight. Easy, just a heat gun, prep solv and some elbow grease.......... Looks Gooooooood..... and added an AVS Arrow Skin II bug shield. Now just to get the wheels powder coated.
Looking for the tailgate handle also. Keep us posted if you find....as will I. Thanks.
Looks very good, except for the rear license plate to glossy id prefer matte black
So how does one go about removing the hood badges? I’ve already swapped the tailgate and grill badges to black, and removed the stick on “RAM” from the doors, but the hood ones have me concerned since idk how they are held on
Held on by multiple clips. Pullup under the number 1 in the direction of the arrow.
does anyone have a number for the black badges on the sport hood?
How did you end up removing the rams head on the tailgate?
i removed they access panel on the tailgate to get to the back of it. There are i believe 3 clips. The whole entire backing of the rams head is adhesive so heat and goo gone is your friend here
Double check but this is what I received from my dealer
CENTER BEZEL : 68402889AB
This was the correct part number. I have been looking all over for this part #.
I have posted the old one with the chrome emblems if anyone wants to plastidip.
