Air conditioning Hack
This is an outstanding thread, thanks for all of the info! We're all on the same team here, and we all want very much to enjoy our expensive trucks. Even if we have to do a little tweak here and there. Welcome aboard!
| NOTE: | The work area ambient temperature must be above 21°C (70°F) and the evaporator temperature must be above 13°C (55°F) prior to conducting the A/C Performance Test. |
| NOTE: | This procedure requires the technician to know what the temperature and relative humidity is at the time of the test. The temperature must be combined with the relative humidity to calculate the apparent ambient temperature ("feels like" temperature), when the temperatures are above 21°C (70°F). Use the current ambient temperature and the relative humidity in your location. This information can be obtained from multiple sources, such as the internet or local news media. |
| Ambient Air Temperature (Apparent) | 21°C (70°F) | 27°C (80°F) | 32°C (90°F) | 38°C (100°F) | 43°C (110°F) |
| Air Temperature at Center Panel Outlet | 7°C (45°F) | 7°C (45°F) | 13°C (55°F) | 13°C (55°F) | 18°C (64°F) |
| Compressor Inlet Pressure at Service Port (low Side) | 138 to 207 kPa (20 to 30 psi) | 172 to 241 kPa (25 to 35 psi) | 207 to 276 kPa (30 to 40 psi) | 241 to 310 kPa (35 to 45 psi) | 276 to 345 kPa (40 to 50 psi) |
| Compressor Discharge Pressure at Service Port (High Side) | 1034 to 1724 kPa (150 to 250 psi) | 1379 to 2068 kPa (200 to 300 psi) | 1724 to 2413 kPa (250 to 350 psi) | 1999 to 2689 kPa (290 to 390 psi) | 2413 to 2965 kPa (350 to 430 psi) |
NoAnyone else notice the air conditioning is not very cold on these 5th gen Rams? Even at max setting. Just doesn't seem very cold to me.
It's a problem for some members. There were about 300,000 2019 Ram 1500's built and I'm unsure how many 2020's have been built. There are maybe 0.10% that are unhappy with the performance because I figure if you don't think it's cold, you'll Google it and get linked here and log in and complain/inquire. I don't think there are 150 members actually complaining about it.
Yes but it is the only solution right now.My '19 Limited was in the shop for over a week with both Ram and the dealer confirming there was an issue. My compressor, temp. sensor, and refrigerant were replaced with no noticeable difference. It'll be returning for a follow up once the weather warms, but having to buy an $8 hose clamp as a remedy on a $60k+ truck is unacceptable.
25-35 degrees? No one else is seeing anything close even with the hack.I did recently add ceramic tint on everything except the windshield, and I'm happy as I could be with the A/C in my truck, before and after tint.
I took a client on a fishing trip last Friday, and after a full day fishing in 90-degree temps and truck sitting in that all day. After we loaded the boat, then cleaned the fish it sat again for about an hour. 4:00 P.M. (the hottest part of the day) got in and began driving back home, and about 10 minutes in with A/C set to MAX the client was shutting his vents off saying he was cold.
I read the hack thread and decided to check my vent temps this morning. It's raining here today, 62 degrees out when I left for my 10 min commute when I got to my office I checked the temps with temp gun with A/C set to MAX and I was getting 25-35 degrees out of all vents at idle. Even if my temp gun is off a bit, my A/C blows some cold cold air.
South La. does get really hot/humid, so I'll do more testing when the temps go up again, shouldn't be too long. This weekend it's supposed to be high 80's low 90's here and it's always humid as fugg. If I need to do a modification, I will, but for now, I'm cool (pun intended) BTW, I keep my house thermostat at 67-68, so that's my comfortable ambient temp. Wife and kids always wrapped in blankets to watch a movie. My little dog (Yorkie) shivers all day unless in your lap or under the blanket with my wife. My Amstaf loves it belly first on the cold ceramic tile or wood floor when she comes in.
Why doesn't Ramcare chime in?
How is it that new trucks have such lousy a/c and it's crickets from Ram?
Probably because this subject has been beaten to death on this and other forums.
Also, maybe they just don't care.
I'm from AZ too and i got the AC Hack "just in case". Blows very cold and i'm happy with the temps, but i have another problem:FWIW I live in Arizona and today is around 104 degrees. I took a 10-mile ride for an errand today, with A/C on Max (initially) and have no real complaints. My truck was kinda in the shade all day and I do have good tint on the side windows, so of course, that helps, but the temp the truck was displaying on startup was 102, by the time I returned home temps were 104.
I25-35 degrees? No one else is seeing anything close even with the hack.
My Kia Sorento does the same thing. I cured it by turning off the AC a couple minutes before my destination and keeping the fan on to blow out the cold wet airWhen the AC gets too cold, it seems like it doesn't get rid of the condensation water and it stinks pretty bad
I tried that, but then i had to smell this crap this whole time... it gets really bad when it blows air with the ac off...My Kia Sorento does the same thing. I cured it by turning off the AC a couple minutes before my destination and keeping the fan on to blow out the cold wet air
