Wheel Spacers
Multiple members have said so far that it would with 2" spacers. Also reviews on ready lifts website states the same. Did you investigate and modify anything?
"Quote:
· 4 months ago
Outstanding!!
This lift for the 2019 Ram is excellent. Easy to installed and looks sharp on my truck. I used 2 inch wheels spacers with my factory wheels and running 35x12.50x20. There is some cutting required to avoid rubbing but not much at all. I believe I removed a 4x4 section to prevent rubbing. Looks great! A must have for any 2019 Ram.
Do they technically fit if you have to cut stuff :unsure:
They only had to cut a 4" piece of plastic from the bottom of the wheel well liner in the front. I would count that as fitting. Lol for some reason this reminds me of the guys that would try and stuff huge motors in the old vw bugs.
Lol, I guess they can say it technically fit :ROFLMAO:
Here are the pics from the venum wheel spacers. These fit fantastic. Everything lined up and installed perfectly. Top notch quality. I included some before and after pics along with the spacer on the hub. I should also note I have the ready lift 3.5" lift kit. Plan on going to 35x 12.5 r20 later on.
I am running 35X11.5 on stock 20" wheels and 1.25" spacers with no rub but very close. If I went to a 12.5 wide tire or if I went t with a 1.5" spacer I would more than likely rub. I achieved essentially the same 3.5" lift only with a different set up.
"Quote:
· 4 months ago
Outstanding!!
I just took them 2” spacers off. There is a decent bit of cutting needed. I wasn’t will to do it. Have to cut about 4in off the front and another 4 off the back going into your fender.
Could 34” tires be fit with the 2” spacers? I think I have about a half inch clearance now with 33s, maybe a bit more. Would be close, I’d guess.
What’s the width?
So happy with the 2” spacers right now!!! Don’t know if I’d ever have enough clearance to do 34s. It’s tight right now, but no rub!
That looks very nice...love the stance on the truck !
It wo
What if you dropped down to 11.5?
it would be tight. Might not rub on flat roads but would probably rub off-road so if you got a pavement princess you’ll be fine but if not you’ll probably have to trim
Stock wheels/tires on my Rebel w 2” spacers. I love the stance.
I have air suspension and no issues all the way down or up.
Hey Ride, can you post a straight on shot? Those look good! Running stock tire right? 275x70x18?
