M3Master
Do you mind posting that link from Amazon?
Has anyone seen an actual fix besides tighten the two inside screws and then the outside screws?
Nice. How long has that worked out for you? I'll probably do something similar to this if it becomes necessary.This was my fix.
Truck only has 1321 miles. So about 1300 miles so far haha. I did the same on my 2 4th gens that leaked and never had an issue.Nice. How long has that worked out for you? I'll probably do something similar to this if it becomes necessary.
Have run the truck through the touchless car wash 3x this week (yeah, I’m bored lol) and no leaks. Hopefully it holds up and doesn’t crack. FWIW my brother has had his 18 Laramie for a year and his hasn’t cracked.Got my truck back yesterday after having it replaced. I will say the slider is a lot smoother, but haven’t water tested it yet. Mine only leaked when going through a touchless car wash, and even then it was only a few drops.
I guess I’m lucky in that I trust my dealer, and helps my brother works there
My rear window was cracked, and only leaked through the crack. As far as I can tell my 3rd brake light isn’t leaking. I’ve never had water spots in the headliner either.What cracks? I thought this was an issue with the seal, not the lens?
What “patches” has Ram being used? I wasn’t aware of any “ patches” that have been use for the cracked window problem or the third brake light leaking problem. Can you be more specific?Ok. Sorry for my confusion. I thought the seal shown was being used on the third brake light. Yes, the window ordeal is a complete joke and Ram needs to fix it and stop patching it.
I could be wrong, but I think what he means is “patching” it by installing the same flawed rear window which will more than likely crack again.What “patches” has Ram being used? I wasn’t aware of any “ patches” that have been use for the cracked window problem or the third brake light leaking problem. Can you be more specific?
Multiple leaks going on. Seems the two most common "rear" leaks are the Third Brake Light OR the Rear Sliding Window. If the cracks appear on the rear window, they replace with what looks to be the same window, however, the part numbers are different.I thought they were replacing the whole back window ?
Take a look at the seal around your third brake light, if you don’t want to wait for the dealership to look at it.I've seen water spots on the window for a while now, but finally visibly confirmed that the cracks are now leaking. Going to have to schedule a replacement soon.
