mangus2k20rebel
- Jun 17, 2019
Anyone have amber lights in the grille like the Raptors? If so, post pics and where you got them?
Here are the ones I used, I did dremel off side tabs and inserted through front of grill. Held in with double sided tape wrapped around barrel of light. I used the smoked lense but amber lense is also available on Amazon.Anyone have amber lights in the grille like the Raptors? If so, post pics and where you got them?
Pretty sure that was entire replacement grill not just led's.Looks nice but I’m looking for something that looks like it came factory. I’ve seen 4th gens with it. I’m also not looking for a whole grille replacement.
Where did you get those?Did these a while back.
Yes and apparently someone thinks i have a bighorn or Laramie grilleThat rough county stuff would be a great template for Police and fire departments.
Can you run the power wire directly to the battery terminal on these leds if you want them always on, or do they need to be tapped into an existing harness?
How did you go about wiring them?Here are the ones I used, I did dremel off side tabs and inserted through front of grill. Held in with double sided tape wrapped around barrel of light. I used the smoked lense but amber lense is also available on Amazon.
BASIKER Auto Front Grille Lights for 2004-2019 Ford F150 Raptor F250 External White LED Lights Decoration | 3 Pack Black Lens https://www.amazon.com/dp/B07VCQ9PD1/ref=cm_sw_r_em_apa_i_GeqGEbF0WVCJZ![]()
All the lights are daisy chained together and I ran the ground of the led's to the driver side fender where there are a couple of ground bolts. For the 12v power I initially wanted to tap into the parking lamp wire behind the headlight but found it hard to get to(not a lot of room to probe for correct wire) and thought it was quicker and easier just to run a wire back to my from my curt T harness that I used for my tailgate bar in the back and tap in the parking lamp wire of t-harness to supply the 12 volts when the parking lamps are turned on.How did you go about wiring them?
these the same under a new link? How did you mount them? I've seen plenty on wiring and even mounting the round ones that fit in the honeycomb of the grill, but these obviously won't fit like that.Amazon but it looks like they're unavailable now. May be able to find something similar though.
Partsam 4Pcs 4 Inch Amber Led Utility Strip Bar 6 Diodes Smoked Submersible Slim Line Led Trailer Side Fender Marker Lights Identification Boat Marine Led Lights Bar Front Grill Lights https://www.amazon.com/dp/B07RW847NR/ref=cm_sw_r_other_apa_i_nKlIEb96CP56S
Looks goodDid these a while back.
My recommendation, for whatever it is worth, is to remove the far right and left LEDs and just go with the three. It will look a TON better IMPO.
