Amber lights in grille
mangus2k20rebel
Anyone have amber lights in the grille like the Raptors? If so, post pics and where you got them?
dts828
Atlanta, GA
Here are the ones I used, I did dremel off side tabs and inserted through front of grill. Held in with double sided tape wrapped around barrel of light. I used the smoked lense but amber lense is also available on Amazon.
BASIKER Auto Front Grille Lights for 2004-2019 Ford F150 Raptor F250 External White LED Lights Decoration | 3 Pack Black Lens https://www.amazon.com/dp/B07VCQ9PD1/ref=cm_sw_r_em_apa_i_GeqGEbF0WVCJZ
mangus2k20rebel
Looks nice but I’m looking for something that looks like it came factory. I’ve seen 4th gens with it. I’m also not looking for a whole grille replacement.
dts828
Atlanta, GA
Pretty sure that was entire replacement grill not just led's.
mangus2k20rebel
Something like this but as an insert. I rather not replace the whole grille.
Maxram
Did these a while back.
Boston
That rough county stuff would be a great template for Police and fire departments.
frybel
Can you run the power wire directly to the battery terminal on these leds if you want them always on, or do they need to be tapped into an existing harness?
Boston
Not only should they be fused, but use a relay so they are only powered when the truck is running.
JBorst03
How did you go about wiring them?
dts828
Atlanta, GA
All the lights are daisy chained together and I ran the ground of the led's to the driver side fender where there are a couple of ground bolts. For the 12v power I initially wanted to tap into the parking lamp wire behind the headlight but found it hard to get to(not a lot of room to probe for correct wire) and thought it was quicker and easier just to run a wire back to my from my curt T harness that I used for my tailgate bar in the back and tap in the parking lamp wire of t-harness to supply the 12 volts when the parking lamps are turned on.
gzgg99
Northern VA
Amazon but it looks like they're unavailable now. May be able to find something similar though.
Partsam 4Pcs 4 Inch Amber Led Utility Strip Bar 6 Diodes Smoked Submersible Slim Line Led Trailer Side Fender Marker Lights Identification Boat Marine Led Lights Bar Front Grill Lights https://www.amazon.com/dp/B07RW847NR/ref=cm_sw_r_other_apa_i_nKlIEb96CP56S
these the same under a new link? How did you mount them? I've seen plenty on wiring and even mounting the round ones that fit in the honeycomb of the grill, but these obviously won't fit like that.
