Talpa
- Oct 21, 2019
3m tape thats providedDude, that's awesome, I just ordered. How does it attach?
Just got the ARE topper put on Thursday
Hey thanks! It’s the V series. No that wasn’t an option on this particular topper. I would have had to step up to a different model to get that. I think I heard with Leer toppers that option is available on lower modeled toppers but I was set on AREMuskiez, your topper looks great. What model is it? Do you have the back door lock synchronized with the main key fob?
Where’d you find that great deal?Ordered a Hellwig sway bar for $125.
I need the link too, thanks in advanceSolved the bad reverse lights situation today. Chose to use two of the LUYED LED lights. View attachment 52328
				 Tapped into the 7 pin with supplied T connectors. 3M taped (supplied) to the bottom of the receiver.      Install:  -Look at your 7pin and look in behind your...
  Tapped into the 7 pin with supplied T connectors. 3M taped (supplied) to the bottom of the receiver.      Install:  -Look at your 7pin and look in behind your... 5thgenrams.com
					5thgenrams.com
				Yoh...’65’... how did you darken the tail lights? If it’s a Limited, you have the blind spot sensors (radar?) in the middle of the lights, yes? I’ve blackened my Laramie fully, except the too-red tail lights. - GaryFinally got my taillights underway, need to buff them out more and might go a little darker. Window trim, body panel and front end chrome delete scheduled for next Friday.
Yes it has the BSM, they’ve been painted and no issues with the sensors. I’m going to go another 50% darker as they’re still not where I want them yet.Yoh...’65’... how did you darken the tail lights? If it’s a Limited, you have the blind spot sensors (radar?) in the middle of the lights, yes? I’ve blackened my Laramie fully, except the too-red tail lights. - Gary
Tinting looks great! How dark is the film he used? They have light, mid, and dark smoke, in either gloss or stealth (satin). It looks dark on your tail lights but light on your headlights? Watching the install videos on the Luxe website it seems like my laramie headlights wouldn't be too bad to do myself. $65 to try it! I would do my mirrors too.Yesterday Saturday , installed my new to me 4PLAY 4P08 wheels ... rec'd them Friday afternoon by fedex ... l traded a set of stock 22" limited wheels for them ... the 4PLAY wheels are 22x10 w/ -24 offset and Haida 878 RT 33x12.50 tires, so happy there is no rub at all in normal mode ... didnt check any other level mode .... truck was leveled w/ daystar spacers and DIY links ...
This morning had my headlights, tail lights and upper 3rd brake light tinted with a wrap ...
for those interested and located in phoenix...his contact info is below...
www.lightwrap.com
Looks good! Tell me about it, it was hard to screw 109982899911 screws for me too...
OEM fender flares.
Was kinda excited to get them after work so install in the dark was definitely happening.
RIP to my wrist. I’ll be ordering a cordless ratchet wrench this weekend.
Nope.. just pushed really hard on them and tightened the screws.. worked for meIt was brutal.
Did you use the 3m tape?
Nope
I have 4.5 inch tips and it’s fine. It doesn’t sit close to the actual tipWhen it's up, how close to the exhaust is it? I'm curious if you can run a larger exhaust tip if u run the step. Looks great!
Thanks. Going with these instead of the license plate frame after seeing your setup.
LUYED LED- New (Frugal) LED Reverse Light.
LUYED Reverse Light EDIT: Install instructions provided by the manufacture LUYED. Please install however you see fit.Tapped into the 7 pin with supplied T connectors. 3M taped (supplied) to the bottom of the receiver. Install: -Look at your 7pin and look in behind your...
5thgenrams.com
