RamConvert82
Boston Metro-West
Been a member for awhile, just never posted any pictures! Here’s my 2019 Ram 1500 Laramie. Finally got the bed rack installed
Dude you can't tease us with just one pic and no details! What'd you go with? How does it perform?
thrasherjosh
So far this is all that I’ve done. It handles and rides just like factory. I wanted a true lift kit but at the time and still now it’s hard to find lifts for 2w/d trucks!
2019 Ram 1500 Laramie 2w/d
Purchased 06/30/2019
15% Ceramic Tint
Huskey Floor mats front and rear
4.5” CST Spindle Lift w/ 1.5” Rear Lift
20x9 XD Grenade Off Road wheels
275.65r20 Nitto Ridge Grapplers
Matching Spare Tire
Line-X Premium
BedRug Bed Mat
Mopar Powersteps
Mopar Blacked Out Front and Rear Emblems
Mopar Bedlight Kit
FrontRunner Slimline II Bed Rack
N-Fab Spare Tire Straps
RetraxOne XR bed cover
Waterfowler41
Chicago
Waterfowler41
Chicago
Bored this weekend so i hooked up the light bar temporarily to see how it looked. Really wish my switches were here...
Eltaco
If you haven’t ordered yet here’s a 20% off link for Lamin-X. They set it up for my YouTube Channel.
And here’s how those fog covers install, super easy
Thanks for the info.
Curious, are your fog lights tinted with Lamin-X?
I’d really love to figure out how to turn my DRL into amber color, but really don’t want to rip the lights apart to change out the LED boards. Do you think a film could accomplish this?
Alternatively, I’ve wondered if there’s any way to wire my turn signals into DRL and signal.
Dookie
Prairieville, La.
I don't have splash guards on my Limited. Maybe you can trim the front splach guards.
I had to do a good bit of trimming, manipulation with a heat gun and wet towel, bend a bracket back and drill new hole for push pins, but I did manage to get to full lock to full lock without any contact/rubbing at all...and able to maintain the splash guards. Only took 4 hours!
Waterfowler41
Chicago
Yes mine are, that video is my walk through on how to install them. It took 5 min per light. Great quarantine project...
BLAM
Congrats bro! I know the feeling. Been there done that, lol!!!
Dookie
Prairieville, La.
Waterfowler41, I ordered some of the Rapid Tac to do my headlights and fogs. In your video, you said it allows you to move the film on the lens once overlaid, correct?
When I did my tails all I used was filtered water on both the Lamin-x and the lens, and no matter how much water I used, the film would stick and not able to move at all. Hoping the Rapid Tac will help ease the install process. If it allows you to move the film on the lens, the tails would have been MUCH easier and likely a better result than I have. If it works like that I may remove my current install and order a new set with your discount and try with the Rapid Tac. Nice install vid, and cute Lil helper dude you have there.
Waterfowler41
Chicago
Waterfowler41, I ordered some of the Rapid tac to do my headlights and fogs. In your video, you said it allows you to move the film on the lens once overlaid, correct?
When I did my tails all I used was filtered water on both the Lamin-x and the lens, and no matter how much water I used, the film would stick and not able to move at all. Hoping the Rapid Tac will help eas the install process. If it allows you to move the film on the lens, the tails would have been MUCH easier and likely a better result than I have. If it works like that I may remove my current install and order a new set with your discount and try with the Rapid Tac. Nice install vid, and cute Lil helper dude you have there.
Yup I’ve never had good luck with water or soapy water mixes. Rapid Tac takes the guess work out. Even if you use too much of it, it eventually all evaporates without residue. It’s a good prep cleaner too
Jeffjad
Southwest PA
Have a link to the plugs you used? I could use some in black.
I actually picked them up at my local Advance Auto Parts store. Below is a picture of the exact retainers that I used and they fit perfect. They come in black, I had to paint mine with touch-up paint and clear coat them.
BiGJZ74
American Canyon, CA
Added the flushmount AVS window vent shades.....I think I’ll have to reinstall as 3 of 4 have some wavyness to them....not sure if i am a fan yet either way. All are in channel except for edge near pillars so that part doesn’t sit flush. Which is hopefully is just an error on my part.
1DA729DA-93F5-48F4-B6E0-6DA6D3AD8E6C.jpeg 79C0DC5C-C53C-471C-9170-F6B956075F8F.jpeg
