Rebel Falcon Shocks/Lift/TFL Truck
did icon put them back on their website?
Yes they have them back on. A local shop quoted me 1520 installed for the front coilovers with instal and alignment. But I’m think of just doing the back ones as well. Just get it over with.
@Cease11; did you talk to the folks over at ICON? I am having issues with my newly installed Falcon system as I did not get same lift results as @Roaminglost and others, so my shop (Desert Rat Offroad) might send the Falcon system back and is recommending the ICON again (which I had for my 2018 Titan PRO 4X). On that truck, the ICONs ran stiffer than the factory setup since they are a digressive shock but ride was still pretty good (not as stiff as the Falcons). They contacted ICON and was told by the rep that he wasn't not sure what kind of lift the 2019-2020 Rams will actually get. I thought that was a pretty weird thing to say but considering they just put the system back on the market, I am wondering if they even fitted a new Ram yet. Or maybe my shop only got to someone answering the phone due to the COVID issue and therefore no one in the know!
Check this guy out. He just got them installed
I'm most likely going to run these falcons till more companies put out something like the Icons. I talked to RadFlo and they have a shock system coming out but don't have all the details just yet.
update on this kit:
you can fit 35s, just have to remove front mud flaps and bend the plastic/ tab back
Roaminglost what offset are those wheel? And what size and model are your tires? I ask because with the right factory wheel offset and a small life you can fit some 35/12.5 tires without any rubbing or modifications
what tire are you running? I want to get the flacon kit and run 35s but dont want to cut any of the plastic. Wondering if theres is a 35 tire out there that runs abit smaller so no cutting.
35x12.5 cooper st maxx
Depending on rim size, you could run a 35 in a 285 (11.2-11.5) width range vs 315 (12.5)
