Cup holders to small
That cup had a small bottom though. Should be able to fit a bigger bottle/cup than this.
Good thing is, it’s my only complaint so far.
I have a 30oz yeti that’s much bigger than a can of coke and it fits fine ‍♂️
Yea but the bottom of that yeti 30 oz is like 2 inches and change in diameter . Because its tapered to fit in a cup holder lol.
Laramie with full console, anyone else think the 2 cup holders on the console are to small? Nothing bigger than a regular sized cab fits in there. Wish it were adjustable or something. Maybe someone will make a different sliding tray with better cup holders ?
I put a 110oz thermos mug in the one big cupholder (console). I have also seen a gallon of milk put there.
the qualifier on the yeti is the handle. when you put a yeti in the cup holder with a handle on it the handle always sits at an odd place in contact with the slider for the cupholder and you definitely can't seat two side by side cleanly.
I agree with that.
My aunt 3D printed this for me.
nicem nt yeti has the slip on handle rung and it makes the handle about 3mm too long to avoid contact with the cup holder, I'd really like the D handle style.
My 2005 Ram has adjustable cupholders. 15 years later, they aren't adjustable...progress!?!
My truck has 12 cupholders, of various sizes...configurations and hard and soft walls. I may have to start drinking more...40oz cup? I'd have to have a porta-potty installed in the bed of the truck. (Unless of course, I was on a dirt road, then as my sister says, as a man, "your world is a toilet."
Just got the yeti 12 oz Rambler with the hot shot cap fits in perfect. This yeti is 3in wide . And the 3 rubber grips get pushed in . This is the widest that will fit for anyone that is curious.
yeti also makes a bigger one that’s 3 inch wide that will fit also. Besides that any yeti that you want if it’s tapered at the bottom it will fit .
All these Yeti’s should fit .
Tiny cupholders make me crazy! How am I supposed to enjoy my latte with 1 pump maple pecan sauce, 4 pumps pumpkin sauce, light caramel drizzle, light foam, with autumn sugar topping, vanilla power, and light whip? ;)
Here ya go, saw this on weathertech's site.
I prefer my 32oz HydroFlask and usually stick it in front of the center console slider, with the slider pushed all the way forward to kind of secure them. The problem is that they slide from side to side and clank against each other during turns. I usually rest my hand on top of it when turning, but it becomes a little tedious when both my wife and I have them stored in the same place. At one time, I shoved a small coat in between the two which works, but it causes issues when trying to put the water bottle back with one hand.
I have been searching for some sort of low profile organizer/larger cup holder that will sit at the bottom of the area in front of the sliding console, but have had no luck. Do any of you know what it is called? The picture below is not my truck, but at least shows the area I am talking about.
