Ellisstrong
Atlanta Ga area
Daystar level and revel links for air ride.
315 40 26 tires and 26x10 rims.
Tires measure out to 35.5 mounted up on my setup. Had to do some minor fender liner and splash guard trimming and molding to get rid of some rubbing I had when turning about 2/3rds of the way. Also had to remove my front weathertech mudflaps. I may be able to trim them to make them work but actually like the look without so I may just remove them.
gatorhwk
Just installed Motofab 2.5" leveling kit with 295/60r20 Faulken Wildpeak AT3Ws. I love the look. Ride isn't bad, but not as smooth as the stock Bridgestone H/Ls (although I didn't like their wet performance). Need to play with air pressure a bit ... currently running 40ish. I am getting a rub at full turn for tight u-turns which bums me out a bit since others have said they're running the same setup (maybe not Faulkens) with no rubbing.
Edit: Rub is gone. Fully screwing down the OEM mud flaps does wonders.
jj_kennedy
Rough county 3.5 in lift on 18in fuel wheels and 35in general tires. Ride is still great handling is good. I would go bigger but hard to lift kids and strap them in when your jacked up any higher.
Is this the kit you installed?
It looks like it levels it out as well, is that correct?
Bufo
Just got my lift put on this week. Went with a 3.5 ReadyLift. I was worried about rubbing since I use the truck on backroads during the summer. So I went with 285/65R20’s to not be as wide. No rub at all so far. I was also worried about how it would look with these factory wheels. I don’t think it looks too bad, but might change them out someday. BAC750DB-F813-41F5-839C-61620047121F.jpeg
texasvolfan15
I think it looks great with the factory wheels...I won't be keeping mine but it is nice to see some trucks with non-black wheels
(I say this as I plan on getting fuel contra's.... :))
RamSco
2019 Laramie ORP, 6" BDS with BDS UCA's and Fox shocks, 18x9 Fuel Vector zero offset 5" backspace, 35 x 12.5 Nitto Ridge Grappler Del 03.17.2020.JPG
RamSco
I'm with you. It's not the choice I made for my truck but it sure looks good on Bufo's
