Talpa
- Oct 21, 2019
It’s doing ok. I’m going to redo it and when I do I’ll sand it down lightlyHow well does the vinyl stick to the textured plastic?
That's for sure. Initially tried a cap wrench and all it did was tweak the bottom of the filter. Band wrench couldn't get enough bite, just slipped. Eventually used 2 stubby phillips screwdrivers, one on each side and it finally budged. Then was able to finish it off with the band wrench.This is the definition of “point of no return!”
lol, that's not a "he", that's a dealer in Phoenix... I use them a lot - their website is moparwholeparts.comI bought them already painted. Pretty much everyone is using the same seller on eBay who seems to have a pile of every color. He has Delmonico Red it appears.
https://www.ebay.com/itm/2019-DODGE...489709&hash=item260532931b:g:02sAAOSwhyZbtoCx
PART# 6RP44NRVAA 6RP45NRVAA
I've read that a lot here... I'm dreading removing mine.They must have the Hulk putting these things on at the factory
Any change? Sound? Butt dyno?Removed the carbon filter and installed a K&N 33-2247 drop-in. Not quite ready to pull the trigger on a full CAI.
How does the dealer get them off?That's for sure. Initially tried a cap wrench and all it did was tweak the bottom of the filter. Band wrench couldn't get enough bite, just slipped. Eventually used 2 stubby phillips screwdrivers, one on each side and it finally budged. Then was able to finish it off with the band wrench.
No, I have not found one yet, but still looking. For alternatives, I installed locking latches to both of my Ram Bins and also purchased a pistol vault that I have cable locked w/i my Ram.
Thanks RammerGuy and welcome to the 5thGenRams Forum! Another poster also sent this link and I ordered the EXxtreme Console Safe(R) the other day. I have yet to install it, but it looks to be a top-notch security vault. And if you use the code "RAMBEAST" you'll save 10% on any order.check this out
Thinking about doing that as well. Received a quote for front film protection (bumper, hood and front fenders) and full ceramic for almost $3000. Sound about right?
A little late to the party but...
Sounds a little steep tbh, i did PPF only on bumper but a full ceramic ultra treatment, aprox 1800
But maybe the hood is that expensive to do?
How much did that run?Had my limited grill wrap today top and bottom of chrome wrap. to body color of truck. center section still chrome Still haven't decided if iit turn out good enough should have went black maybe
Did a little vinyl wrapping
Looks great! What brand vinyl did you use?Did a little vinyl wrapping
Ram should offer a sport package on the Limited. That looks awesome.Toned down the brightness today. Upper and lower grille painted to match. The center section is wrapped in brushed black. Harmon Customs RAM logo with white backlighting. Mirrors wrapped in gloss black.
