Dustin
IT Geek, Adventure Junkie
Nice job on that bike rack. Can you share some details on how you made it? What did you use for the cross bar and how did you secure it to the side rails? Thanks!
I used a 1x4 of hardwood. I had to notch out each side so it would fit in the wide part of the rails. I took the plastic cap off near the front of the rails to install them. I did use some metal plates (top and bottom) to help reduce flex and add strength. Below is a picture of where I notched the wood.
It is kept in place by moving the bedrail slide up as far as possible, then tightening them down.
