Billet1500 4x4
Yeah that would be the case unless you added a top hat spacer to bring the front up a little bit more. Hopefully they have a long travel version in the works. Icon makes a long travel version for other models where the shock is physically longer and adds 1" of suspension travel, requires UCA replacement but they are typically a full race shock with remote resi with CDCV, right inline with a set of Fox, King or Radflo in performance and price. Fabtech also has a kit with a full coil over replacement. Below is a rebel with the Fabtech coil over kit. $2900 non resi, 3300 with resevoirs but no damping control circuits.I agree that the icon is a better setup but if you have a Rebel or ORG springs, wont it only get you 1.5" of lift in the front? Same with the king coilover setup? So while your actual suspension setup is better all around, you're still not level unless I am wrong here.
