285/60R20 on stock suspension + stock wheels 20x9
I was not totally sure whether these tires would truly fit and function nicely on my stock suspension 19’ Big Horn Black Appearance Package. I read lots of posts on this forum but many seem to include tires of larger size coinciding with a level kit, full suspension lift, Ram Rebel, or air ride. Any of those can lend a great help to achieve proper ride heights for a larger A/T tire.
Today I pulled the trigger and had installed 285/60R20 Nitto Ridge Grapplers on my stock 20x9 wheels. These have completely changed the looks of my Black Appearance package Ram, in a very good way.
View attachment 26334View attachment 26335View attachment 26336View attachment 26337View attachment 26338
I do have a slight tire contact with my fender flare plastic during “FULL” lock while in reverse. However, this is trivial and the contact sounds like a baseball card placed in the spokes of a bike, turning at low speeds. LoL. Eventually I will get a level kit, but for now I’m not in a hurry.
Also, my speedo was reading at 71 on the highway while my GPS was clocking me at 73/74 (fluctuation). So a 2-3 mph difference. I plan to get the Rough Country calibration unit to sync my speedo and tire rotations.
Thanks all!!
Glad I ran across your post. I've been trying to decide between 285/60r20 and 285/65r20. Same tire. Definitely think I'm going with the 285/60's. I have the Bilstein' installed on the front so I shouldn't have any rubbing at all
Thanks all!!
They look great!
I wonder if they ORP would clear without any rub?
Awesome. I have my front set of Bilstein sitting in the garage awaiting me to schedule the install date. How’s the ride after installing? I am all for leveling but would hate to feel a reduced ride.
It's actually much tighter now and allows you to feel the road a bit more so to speak but not in a bad way. Doesn't ruin the ride quality, makes it better in my opinion. Less lofted bounce feeling on bumps. I feel more in control now. I went with the 5 setting. Seemed to put me at almost 2". Leaving me with the rear up only a 1/4" now. Which is perfect for me because I feel it I would have went higher it would look nose high.
Nice. Looks great. Thanks for the settings tip.
—-|||RAM|||-—
Phil
sent from my mobile device
Thanks all!!
Looks good, looking at same size in a Goodyear Duratrac
Thanks all!!
Looks great, big difference from stock
Got the Nittos installed this morning. I like them so far. The guy at Discount Tire showed me a slight rub in the front against a plastic piece of the wheel liner. But it's only in reverse and only during a full lock turn. I could trim the plastic a bit, but I'll probably just leave it alone.
A little more road noise than the street tires, but that's to be expected with AT tires. And the increased noise is really only noticeable at highway speeds of 65 and up. The ride is just as comfortable, if not maybe a little better than the street tires, and the Nittos track and handle very well. Plus, they look good. I'm pleased with them.
Sorry to bump an old thread.
Do you believe the 285/60r20 would work with gatorback mudflaps?
Interested as i also have air ride.
Hoping for a little help. Our daughter’s stock 2019 1500 Big Horn (black trim & wheels) without air ride or lift and 20” wheels, is in need of new tires. I’m hoping to go a little bigger without any rubbing issues. Looks like from what I’m reading is a 285/55/20 would do the trick. Any photos or confirmation on this would be very helpful. Want to pull the trigger on some Nitto Ridge Grappler’s asap. Thanks!
Oh… She also has the OEM mud holders… I mean mud guards! Lol!
You won’t have any issues with that size.
Hello everyone! Long time lurker, and first time poster. Over the last several weeks of researching and reading over the post on here, it has helped me tremendously in my decision for tire size. So I thank everyone for that.
My truck: 2023 Ram 1500 BigHorn. Factory air ride with a 2 inch ready lift, leveling kit which includes new upper control arms. I also have installed after market o.e style fender flares and the gator back mud flaps front and back as well. Otherwise everything is stock and stock rims. Last week I pulled the trigger on WildPeak At4's, 285/60/20. I can confirm that it fits with zero issues with a setup like mine. Clears all mud flaps/fenders,bumper, control arms etc. The closes clearance issue; is between the upper control arm and outter inner tire wall at full lock. Even so, there is still a fingers space worth of distance between the two. I'm not comfortable with wheel spacers, and aftermarket offset rims aren't in the budget so this route was worth the shot.
Anyways, I can comfortable say im happy and glad this setup works no problem on this style truck. It completely changed the look of my truck and even added height.
I figured I would post this incase anyone need further validation with a similar setup. I will include photos as well.
Truck looks great. I'm a new owner of a 2020 bighorn and it's completely stock. After Christmas, I'm gonna level it, and up size tires.
I owned a set of Falken wild peak atw3 305/55/20s on my Silverado. Best tires I ever owned, or heard of!!! I put them on the truck at 95K, and replaced them at 205k!!!!!
110,000 miles, and if I hadn't stopped rotating them at 95k, I think I could have made another 10k. I kept them aired at 48psi, rotated them every 10k or so, and believe it or not, (I haven't told my dad, cause he would disown me) I never had them rebalance since Install! I don't recommend that part. But they never had a vibration, and never worn the edges or cup. Now they were absolutely worn out when I pulled them, but they still handled great, no hydroplaning. Smooth, quiet, plenty of traction. Best tire ever.
I realize others may not have gotten that many miles out of theirs, keeping them aired close to 50 will help even wear. I also spoke with a guy that worked at the goodyear plant, and he said tire manufacturers could make a tire that would last the life of the vehicle, but they would be hard, and uncomfortable to run. He also said some times a batch of tires will get cooked a little longer, and they will be a longer lasting tire. Manufacturers want smooth handling, but they also want you to need tires again. So maybe I got a set that were just perfect. They were that.
Anyway, long rant. Love your truck
Just completed Bilstein install with 275/60R20 AT4's and there's plenty of room in there for 285's after the install. I also have Husky mudflaps and there should be no reason why 285's would even come close. 60's should be no problem at all.
