So, where’s all the trucks with 4” lift?
Turbo1895
NY
North Edition (1" taller factory struts), 4" BDS, 305/65R18 BFG AT KO2's on 18x9 Fuel D551 with +1 offset
I also have a north edition, and I am wondering how is this kit effected by the factory struts being taller? Did adding this kit effectively give you a full 5" lift (4" Bds kit + 1" from the struts on a North Edition) or did you only get 4" in Total? I am trying to get a full understanding of all the options before I make a decision on what I want to do with my truck.
Right now, I am thinking I just want to add something like a 2.5" RL leveling kit with new UCA's but I am not sure if 35's would fit on that set up without rubbing.
Your truck looks great btw.
SilverSurfer15
It is 5”, as long as you are reusing the stock spring you’ve got the 1”. If you switch to a replacement coilover, like the fox ones, you’d lose it and be just the 4”
Leif_Ram2019
Seattle, WA
It looks like BDS has a 4" lift kit for the standard pick-up and a separate one for the Rebel. Which would be the appropriate kit to use on a truck with ORP?
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
Here’s mine with 4” BDS up front and stock rear (for now). I really didn’t expect it to lift the front this high, which is why I thought I could get away with leaving the rear stock but I now know I need to lift it probably 2 inches to get it level or just slightly nose high (which I like). I did 315/60r20 tires which are about 35x13, and 20x10 -24 wheels. There was veryyy minor metal trimming that the shop took care of and some plastic trimming of the fender liner that you can’t tell at all.
Ram1992
Houston TX
Nice looking truck !
ksn240
Is BDS still the only one out with a true 4" lift kit? I remember Fabtech teasing one a while back and people commenting that Superlift had one on the way. I don't want the 3.5" kits as the ride quality will quickly go away and I don't want to have to worry about the angles.
PorBoy
Millville NJ
I’ve looked and I’ve only seen 3.5 or 6” ones on those sights. :(
RamSco
Looks great so far. It will look (and probably ride) better when you execute your leveling strategy.
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
Thanks! Yeah it’ll definitely look better & im hoping the ride is even better with the bilsteins! Time will tell!
pber1
Santa Rosa, California
Badass bro! It sits perfect
PorBoy
Millville NJ
Well this time next week I’ll be part of that B.D.S club. I thought long and hard about a 6”, but realized the 4” would be spot on for my needs.
Ram1992
Houston TX
If I may, whats the reason you want to install Bilsteins? I’m considering lifting the my truck with 4” bds but I’m concerned about the ride quality. I’ve got a leveling kit now and I’m not happy with the ride Quality or the height I got.
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
I figured the Bilsteins would offer a little smoother ride both on & off road, but honestly after reading people’s reviews of them for the 5th gens I think I decided I don’t want to buy them after all. The truck rides AMAZING with the 4” kit. The only thing is on big bumps or Offroad the truck is a little stiffer than stock but I attribute that 100% to the stiffer tires, not the suspension. I 100% recommend the BDS kit, I could not be happier!
rrjjpp74
SW PA
What is your turning radius like? I have the 3.5 but been thinking of going up and going to a true lift. But was wondering how much the turning radius has been affected.
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
I’m not sure that suspension lift affects turning radius.? But I thought the turning radius sucked stock and it still sucks now lol but I guess that’s natural for a crew cab with the 6’4 bed
Ram.Rebel.19
For the guys running 4" BDS lift... are you running with stock upper control arms? I dont see a UCA option with the 4" BDS kit so i guess its not necessary to swap it out?
