Swapping Halogen Light assembly for LED assembly?
TheMadDutchDude
I'm in the same boat as you, dsn. I would do the headlights first, but I need to do the taillights too... my OCD wouldn't allow me to leave it.
Drack, that's a decent price! Shame my bank doesn't allow for a purchase right now. Thank you for the offer, dude. :)
MBORO19RAM
Looking for these on the cheap.
PN 68316088AG and 68316089AG
If anyone is selling let me know.
Thanks
Heli-Pilot
Central Oregon
Hi there! Would love to retrofit LED head and tail lights on my 19 Bighorn. Do you have part numbers you used? Any advice would be greatly appreciated!
MERRY CHRISTMAS!
Kevin55
Texas
I was in the same boat that you were in. I got every option on my truck but because it’s a big horn I couldn’t get the LED headlights when I have a crew Cab Long bed, pano roof and premium sound. Can’t even make it on the build your RAM on the website. So I ended up buying led headligt bulbs and switched every bulb in the front end to LED. Big difference and makes it a whole lot better. I will also be lightly tinting my headlights so it gives it that dark look like the LED factory headlights have. That will be done in the next month
Can I ask what LED you went with?
Kevin55
Texas
Never mind, I seen you added that info later. Thanks
Jmarchese
Hey all. Picked up a 2020 big horn. I replaced the halogen fog assembly with the OEM led fog lights that come with the premium lighting option. Install was smooth, but fogs will not turn on. Dealer said I may need to get computer reprogrammed. Anyone experience this issue or install successfully?
Livinfast85
Pearland Texas
If you get a Tazer DT you can enable them
JDiMassa8
Ohio
so I finally drove at night with these lights. I can confirm that the headlight revolution led headlight bulbs for the halogen assemblies are brighter than these OEM led headlights. Sucks they are now sitting in the garage.
NorthEdition19
PA
I try to warn people before they spend the money and time, it’s not worth it
JDiMassa8
Ohio
Ya because looks outweighs being able to see
The LED assemblies are still 10x brighter than the halogen assemblies. Everything is very well lit. The halogen assemblies with the headlight revolution bulbs are almost too bright because you end up blinding everyone else going the opposite direction as you.
Nmassahos
are you selling the headlight revolution bulbs?
ak_andy
Louisiana
Hey, guys I'm new to the forum. What are the differences between the LED w/adaptive headlamps and without? Do I really need the adaptive?
JDiMassa8
Ohio
Im actually keeping them for now. I actually have 3 bulbs which is the funny part. I’ll let you know if I end up selling. I’m keeping them just in case I have problems with these led assemblies (which I have ran into one now).
robber98
Have you checked the adjustment on your headlights? There is a good chance they are set too high especially if you’ve done a lift or level.
Jmarchese
I installed the Tazer DT, it is updated with the newest software. Enabled fog lights and turned LED fog lights to yes. Did a reboot and full shut down, even tried disconnecting the battery and fogs still wont turn on. Am I doing something wrong here?
JDiMassa8
Ohio
Yea I redid the headlight alignment at work. (I’m a Auto-tech). They are still bright no doubt about it. But that headlight revolution bulb is brighter. But I still see a lot more clear than the stock halogen bulbs and assembly. Still very happy with it. Currently having a issue where the high beam on one side is constantly on with the low beams. I’m gonna swap the adapters around and hope that it switches to the other side so I could just get a new adaptor. I don’t feel like taking everything apart again
