Falcon - Teraflex Kit out
Welcome to the forum, do you have a 1500 DT showing these installed ?
I was just posting the email that Anthony from Falcon sent me. I had emailed them/icon/etc back in Dec to see what the timelines were for these, and he responded today.
$1529 seems a bit of a stretch to me vs the icon stage 1 but you will get a true 2.25" level on these vs the coilover setup, plus the versatility of those adjustable rears for those who tow a lot.
Is this the system that the TFLTruck YouTube channel used on their "Rebel Rouser" project truck? If so, there's plenty of footage on this system on their channel.
Yeah, seems a bit pricey, if carli stays in same price range as the 2018 kits it’s only 1900 for coil overs, rear springs and shocks and few other parts.
curious if this kit is worth the 1500 price tag
So looking it states it fits 2019+ 5th gen rebel and then goes on to say 2019+ 5th gen does NOT fit...any reason why it would not work on a non rebel 1500 or am I missing something?
Read it again. It says does not fit Classic.
So the big question is .... will it raise the rebel 2.25” or sonce we have aftermarket suspension we only get 1.25” ??
It’s the full 2.25” since it uses the Rebel shocks which is where the lift comes from I am pretty sure.
I’ll leave it to smarter folks than I to really confirm but my understanding is that the Rebels and ORGs get their lift from a larger spring (strut length is the same), so by this package being just struts and not full coil overs, you would gain the full amount of lift. Whereas coil over setup like icon or king replaces the front spring with a “normal” size spring in the front but re-uses the larger spring in the rears, resulting in less than full lift. Look at the pics of the white Rebel on icon’s site and you’ll see it still has some rake.
This. The icon setup is more bang for the buck here IMO. But I wonder how much discount you could find on either....
Had them for a week now. All I can say is truck is on rails now. Very confidence inspiring on sweeping and twisty roads. The little amount of off-road and snow was awesome.
Truck setup with Level setting and 1.5" Spacer in back to maintain a slight rake. Helps with the lights projection as well.
Tires are Cooper AT3 Xlt 285 /65/20 with no rubbing.
No regrets with the simple level combination
20200301_145624-jpg.48357
Please explain your full setup.
Rampat
Are you messing with the newbie? :} Nothing is different than the my post. Falcon set on "Level" setting. 1.5 spacer on the rear to maintain a slight rake. That is it. 285/65/20 running 40 psi which I might lower the psi to soften it just little for slower speeds. But anything over 40 mph everything really smooths out nicely. This is my first rear coil suspension rig and it felt a little loose and springy in the rear with the stock setting. I suspect any decent aftermarket shocks will improve this rebound dampening from stock. In the stock setting could feel the road lane separators/ delineators in different way than my previous F-150. Thought it was odd for slight loose feeling changing lanes. Little things you notice right away how planted truck rides and tracks. The lane separated are not even present now. Eventually plan on putting a camper shell on which I think will only smooth it out even more overall. Anyhow they are little spendy but believe they will be a good long term investment for these awesome trucks.
Rampat
Also posted in another thread but asking here: Last check-in before I hopefully pull the trigger today: How are they on-road? I'm trusting that all the brands (icon, falcon, king) will be amazing off-road and will all do a great job of absorbing the bumps at high speed/not bottoming out/good firm and stable track. How are they during daily driving though? I don't want to bounce the wife and kids through the roof with my 80% on-road driving just to feel a bit better than stock on the off-road stuff or when towing. Low speed bumps, around town I assume are worse but are they BANG/JOSTLE worse or just stiff feeling? Anything highway I expect it to be stable and absorb the road due to high speed dampening?
