Have you had any problems with it? I’ve heard nitto’s hybrid tires ride pretty smoothly. I’m kinda debating on 4” vs 6”. It’s too hard to decide.The ride quality change will be more related to the tires you choose versus the suspension lift. The heavier/stiffer carcass on the tires will simply transmit more road harshness than the 'C' load range OEM tires, particularly with a 20" wheel. I'm very happy with the ride quality of the BDS 4" overall.
Did you rock the coilovers or just go with their std 4in lift? I'm running the 3.5in Readylift and am looking to pull the trigger soon on the BDS std 4in lift. Its around 4K installed- I don't think I need the coilovers and would like to save the additional $$. I'm sure the ride will be far superior than the Readylift.Haven't had any problems whatsoever. Lift height is a personal preference thing, I'm pretty happy with how the 4" turned out in my case.
Pretty sure they don't make a 4" coilover kit yet. That option is only available for the 6" kit.Did you rock the coilovers or just go with their std 4in lift? I'm running the 3.5in Readylift and am looking to pull the trigger soon on the BDS std 4in lift. Its around 4K installed- I don't think I need the coilovers and would like to save the additional $$. I'm sure the ride will be far superior than the Readylift.
On the 6" BDS kit the lift in the front comes from top mounted steel fabricated strut spacers along with preload spacers. So, you could imagine this stiffens up the ride a bit. The coilovers remove the spacers all together.^^^. Clue me in please what all are the benefits behind the coilovers ?![]()
Yup...just checked...ThanksPretty sure they don't make a 4" coilover kit yet. That option is only available for the 6" kit.
So is the BDS 4in lift front suspension going to be comparable to the 3.5in Readylift ride?On the 6" BDS kit the lift in the front comes from top mounted steel fabricated strut spacers along with preload spacers. So, you could imagine this stiffens up the ride a bit. The coilovers remove the spacers all together.
The 4" BDS should ride better as it is only using a top mount strut spacer, no preload spacer. The BDS also comes with the needed drop brackets to correct the suspension geometry that the Readylift kit does not. So, technically the BDS lift will not wear out the factory components like the Readylift will.So is the BDS 4in lift front suspension going to be comparable to the 3.5in Readylift ride?
I've been pestering them when the 4" coilovers will be available. They just released on Instagram a 4" coilover system for 2019-2020 GMC 1500 trucks. So, hopefully we are next.Yup...just checked...Thanks
If anything just get the 4" or 6" basic kit for now and get the coilovers down the road.The 6k price tag hurts with all the mods I've done already!
If BDS does release 4" coilovers, then yes. You would just be replacing the factory strut assembly and BDS spacers with the coilovers. Plus a new alignment.is that an option, if i get the 4” lift, I can add the coilovers after they are released?
