Hello all, I just bought a use 2019 Laramie and my upper glove box light would not go out. I have fixed it myself by taken the dash apart, the upper glove box is a one piece unit. on the right side of the unit there is a mico switch that turns the light on and off, as the glove box lid is closing the arm of the door rotate and pushes the switch open shutting off the light.
On the right arm of the glove box is felt tape that push against the switch, this tape is not thick enough to push the switch open so I added four more layers of electrical tape and that did the trick.
it took me about an hour to take the dash apart and only a half hour to put it back together.
