768mph
- Jun 24, 2018
LUYED Reverse Light
EDIT: Install instructions provided by the manufacture LUYED. Please install however you see fit.
Tapped into the 7 pin with supplied T connectors. 3M taped (supplied) to the bottom of the receiver.
Install:
-Look at your 7pin and look in behind your bumper.
-Disconnect your 7 pin by releasing the black push tab (clockwise 2 oclock position)
-Disconnect gray wire cover by depressing two gray push tabs and release
-Cut away stock black tape to reveal wires.
- Use T connector for 7 pin White Wire (ground) and black wire: 7 pin 7 oclock position
-Use T connector for 7 pin black wire (power reverse) and red wire : 7 pin center positon
Tape back up with electrical tape to protect and mount where desired with supplied 3M double sided tape. Use alcohol to clean area good.
* helpful tip- wires with LED are 20ga. Double up on the (fold over exposed wire) within the T connectors. Better contact.
** Always test the light before taping everything back up and mounting.
Install:
