Mine would just be a duplicate of wahudiditagain’s post- same Mount location and angles.Doesn't count if you done have pics.
I mounted a pair but the wiring is incorrect and I haven't bothered to correct yet.
which Tee connector did you use? ThxGot the plumbing done, just waiting on the lights to get here, COVID19 has my shipment slowed up.
View attachment 54530View attachment 54531View attachment 54532View attachment 54533
No.Those that did the T-harness does the truck show a trailer plugged in with this setup?
That's correct.So from what I gathered for the LUYED wires, red to reverse and black to ground?
I didn't even think to test it before and already did all the wiring for the lights. Its ready to be plugged into the curt harness once it gets here. If I have to, I’ll just do it over lol
With this connector, will it replace having to Splice lines in place? Can I just plug this in, connect the lights and go, essentially?
Amazon.com: TIROL 5-Way Flat Trailer Wire Harness Extension Connector Plug with 36 inch Cable Length End Connector: Automotive
Buy TIROL 5-Way Flat Trailer Wire Harness Extension Connector Plug with 36 inch Cable Length End Connector: Connectors - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Yes, the curt harness plugs into the truck creating an extra 5 pin flat connector. You solder your lights into the other flat pin connector, plug and mount.With this connector, will it replace having to Splice lines in place? Can I just plug this in, connect the lights and go, essentially?
If you wanted to do 2, would you just solder both to the same connector and use 1 harness? Or would you have to daisy chain them / would that even work?Yes, the curt harness plugs into the truck creating an extra 5 pin flat connector. You solder your lights into the other flat pin connector, plug and mount.
I did two, just solder two wires from the lights into one wire on the 5 pin flat connector.If you wanted to do 2, would you just solder both to the same connector and use 1 harness? Or would you have to daisy chain them / would that even work?
Ditto. No issues with mine. Installed back in January.I’m running the same setup with the curt harness. Very easy install and I love these lights.
Just did this, same led's, same placement and used the Kurt harness which I cut off and soldered the led's to. Very happy, thanks wahudiditagain.Installed two of these, one on each side of the hitch bottom. Fantastic results. I might use a few of these for bed lights.
View attachment 45112View attachment 45113View attachment 45114
