Rampat
Put it in Sport + and plus 4 and floored it. Then this picture happened. Told me to service throttle and traction control.
Check engine light, traction control light and 3 other lights I don’t know. This piece of junk is going back.
Disconnect your negative battery cable, and reconnect. Light should clear. You will need a 10mm socket I believe.Turned it on and off multiple times. All other lights went away but the check engine light remains on.
Why would it have set all those codes off? I thought this thing never did that.Disconnect your negative battery cable, and reconnect. Light should clear. You will need a 10mm socket I believe.
Ooopsie.Put it in Sport + and plus 4 and floored it. Then this picture happened. Told me to service throttle and traction control.
Probably spooked the pcm - couldnt keep up with input readings .... I think battery disconnect will probably work (it has on stuff like that in past vehicles I've had).Why would it have set all those codes off? I thought this thing never did that.
I wouldn't ditch it based on what you did... of course it's qyour decision.Check engine light, traction control light and 3 other lights I don’t know. This piece of junk is going back.
I just wanted to see all ends of the spectrum before landing somewhere in the middle. I haven’t disconnected the battery yet. Left the Ram at home and went to a friends house for a New Years Eve Party.Ok
The instructions do say, sport plus is for drag racing (iirc)...
When I ran it in normal Sport +1, 2, 3 - I knew Sport plus would be way overkill for street use.
When you reconnect the battery, let the truck sit for 20-30 minutes so that all systems can reboot before you start it. If you don’t, systems like AC, XM, Controls will be unavailable.I just wanted to see all ends of the spectrum before landing somewhere in the middle. I haven’t disconnected the battery yet. Left the Ram at home and went to a friends house for a New Years Eve Party.
I know I did this once with my Raptor. Ran the pedal commander in the highest mode stacked with a tune from MPT...dash lit up like a Christmas Tree when I gunned it. I think it sends signals that are WAY outside normal parameters and the PCM gets overloaded trying to process. Disconnected all, battery reset, and all was good when I reloaded my tune.Why would it have set all those codes off? I thought this thing never did that.
I started at city +2. Ran 15 mins at sport +4, over kill for my driving style. for the past week, i’ve settled on city +4. Very nice off the line acceleration if I wish to be first .
Try unplugging the PC and going back to stock... I'd do bat disconnect again at that point - and see if light stays off.I disconnected the battery. Engine light went away. I switched it down to City 2 and didn’t even put it in drive and it set off the lights again.
I have a feeling that’s my problem tooLove this thing, but when I use the bluetooth to change settings, it throws all kinds of codes. It doesn't do it when I use the unit itself, only when using the app. I disconnected the negative battery cable, cleared everything out and and tried again with the app. Same thing. Now I only use the unit to change settings with no issues, but can't hide it like I would like to. Anyone else experience this.
Even with this issue, still happy and loving this thing.
Don't have mine installed yet but are you changing on the fly while driving, stopped with engine on or stopped just key on? Wondering if it makes a difference.I have a feeling that’s my problem too
