GraniteRam
- Jul 15, 2019
921_36_5.5K_N for the cargo lights and 921_36_R for the third brake light. All three are 921 bulbs.Can I trouble you for the part numbers?
Thank you good sir.921_36_5.5K_N for the cargo lights and 921_36_R for the third brake light. All three are 921 bulbs.
2019 2020 Ram 1500 LED Bulbs Upgrade|Lasfit
All LED bulbs are for the new 2020 2019 Ram 1500. Every part of RAM 1500 LED bulb replacement is engineered with more expensive OEM-grade features to assure quality.www.lasfit.com
I am obviously not anyone else, but I did buy the entire kit, zero issues, and the brightness of the low and high beams are amazing compared to the *yellowy* dim halogens.This light system looks awesome. Can anyone else personally vouch for these over the halogens? Also, will this affect any warranties at all?
Let’s get a write up!Tiny little LED reverse lights. $12 each on Amazon and incrediblely bright. Couldn't see jack behind me with the stock reverse lights. I used the 7 / 5 pin Curt harness. Nice little project.![]()
The only lights that suck are the reverse lights, not much difference from the originals.
And in my opinion, the map lights are the hardest to replace.
Not sure about potential warranty issues, maybe someone else can answer that.
Today I installed over 50 Sqft of Sound Mat in the doors and rear of the cab and then re-installed my JL Audio C2 6x9"s and the dual 10" JL Audio Subwoofers. Put in a solid 11 hours today to get everything installed and wired up and need 2 or 3 hours tomorrow to button up the loose ends, tune the system to my liking and re-install the rear seats. I did the same install on my 1st truck and found it to be a fun project, installing the same equipment in the same way on this truck, just to get it back to the way I had the 1st one felt like a complete chore. The 2nd time around it was easier though and the install has come out neater and cleaner overall. Just sucks having to waste so much hard labor to get back what you already had completed once. Oh well that is enough bitching and moaning for now and tomorrow or Tuesday I will wrap it up and be done with it.
The box is made by Fox Acoustics and fits perfectly under the rear seat. They have a few other options as well if you wanted to go with a single sub or sealed box. Here is a link to their 5th Gen products:I would love to see some picture of your subwoofers and the box?
Thanks
Do those visors have a matte finish?EGR In-Channel Visors and new Covercraft windshield cover.View attachment 42875View attachment 42876
