toxicfusion
 - Jul 23, 2019
Question:
on the new mopar UCA, there is a long bolt that goes through it and then an tear drop shaped washer on opposite ends of bolts. Which position. One side of vehicle its sticking outward, other side its facing down touching the frame. Unsure of original position of that. The creaking sound nearly sounds like brake pads sticking and pulling off the rotor (similar sound). NO odd noises over bumps and grooves, that is smooth. so unsure. perhaps its swaybar endlinks and they need to be torqued to the new 62ft-lb specs.
