GraniteRam
- Jul 15, 2019
Go to the first page, you'll find your answers there.
I believe all the Mopar wheels have an +19 offset. I run 285/65R20s with no spacers on mine and it’s pretty tight if that helps any.This question has probably been asked/answered but I keep finding conflicting info or a similar but not exact question/answer.
Can you run the stock 22x9 wheels with a 35x12.5r22 with the Mopar 2 inch lift? Anyone know what backspacing/offset the stock 22x9 wheel is? What is the recommended/ideal offset to run the 35x12.5s to have minimal trimming? Would like to keep wheels as flush as possible. If the stock wheel offset isnt ideal, can a wheel spacer like a BORA be used to push the wheel out, what size? Thanks in advance!
I just got quoted 2k. I’d love 880.I just had a dealership quote me for lift install with alignment, $880.... That seems very high. I was anticipating $400-600 range.
2k just for an install? That's insane. Around here you can get a 6" lift + install for that and still have money left over.I just got quoted 2k. I’d love 880.
That was the out the door price for the fox mopar 2 in.2k just for an install? That's insane. Around here you can get a 6" lift + install for that and still have money left over.
I have this kit, ORP springs and the hellwig rear sway bar. I’m going through the parts to get ready for a Friday install and I’m missing a few small parts from the lift kit.
I’m missing a bolt labeled “J” it’s the one part with no description and I don’t see it being used on the install.
Also missing a nut Labeled “V” (rear upper shock) In the instructions it says to reuse the current nut. Should I not worry about either of these parts?
Update? Curious what your thoughts are on the ride quality with the ORP springs. Pics too if you have a chanceI have this kit, ORP springs and the hellwig rear sway bar. I’m going through the parts to get ready for a Friday install and I’m missing a few small parts from the lift kit.
Here you go
Glad I’m not the only one. What gives? Any idea why the bed length would at all cause this lift to not work or not be safe?I was at the dealership ordering my exhaust today and heard a gent complaining they won’t do his because he has the 6’4” bed also.
The Mopar lift will work just fine. For whatever reason the dealership says it won't work on quad cabs or long beds but the suspension setup is the exact same. There are a few people here that have it on quad cabs with no issue, not sure about the long bed but there is absolutely no reason it will not work.Glad I’m not the only one. What gives? Any idea why the bed length would at all cause this lift to not work or not be safe?
The gal said they’d do it anyway, but I’m waiting for the tech who does lifts specifically to call me on Monday to make sure.
Would love to know why they don’t offer this for 6’4 and if there are any reasons I shouldn’t go this route?
Thank you. Sounds like my dealership will do it, but they have not done one yet on the 6’4 bed crew cab. So I just wanted to make sure before I spend the money on labor and then get told it didn’t work, ha.The Mopar lift will work just fine. For whatever reason the dealership says it won't work on quad cabs or long beds but the suspension setup is the exact same. There are a few people here that have it on quad cabs with no issue, not sure about the long bed but there is absolutely no reason it will not work.
