ColoradoCub
For those of you that keep the auto start/stop feature on these trucks enabled, does your AC get extremely warm when sitting at a light? I've had to disable the start/stop because I was sweating to death with my AC on the lowest it can go. I was starting to feel light headed because I was so hot and the truck wasn't cooling down; however, after I started driving with it disabled and had the truck constantly running after about 8 minutes it started to blow cold. I took my truck into the dealership once for this warm AC issue and they said my system was low on freon from factory and did not have a leak, they "filled" the system back up to spec and everything looked "normal" - that was a month ago, I'm still sweating my *** off.
yeah the start stop turns your engine off so you have no AC when it’s shut down at a stop. It’s supposed to know it hots out and not shut off but I’ve found the system to be poorly programmed. My F150 that had this feature and would not shut off all the time when it was hot and the AC on, this truck always shuts off at a stop.
