RodRow
If it was a May 2019 build how did you pick it up in December. December 2019 isn't here yet still have 6 months.
 You got me! Corrected in my post above.
 You got me! Corrected in my post above.If it was a May 2019 build how did you pick it up in December. December 2019 isn't here yet still have 6 months.
 You got me! Corrected in my post above.At the car wash today and now I’m seeing the same issue. Mine was a May 2018 build bought new in December.
Taking it in soon for another faulty backup camera, squeaky brakes and recalls.
mine has a small crack and i do have a small leak but it is not coming from that side. i swear some of my leak is coming thru the 3rd brake light. i have a hunch its not coming from the back window.
Can you post a picture to show exactly where the leak is. Also is the back carpeting under the window wet.Just went out to the truck. I have leaking at the back window same spot but no crack with damp headliner with Fixed sunroof drains. Nov 18 built
Geotex1, any idea on the TSB? I don't see it anywhere on the listed TSBs. Unfortunately, after almost a year and 12k, I have the dreaded issue of cracked frame and water intrusion.Leaking 3rd is also known issue. There's a TSB.
	Mine is going to selling dealer this Friday. I asked the service advisor if they had seen any trucks with this issue, they said they hadn't. Will keep this thread updated as issue progresses. My build date is 8/18, so I am seeing a very small trend with us responding to this thread.Does anyone know what is causing this issue?! I have been religiously checking mine. Build date is in august of 2018.
Sigh - I've got 2 cracks and a trip through the carwash confirmed water getting inside.
I had traded in an F150 for numerous problems, one of which was water leaks. Taking into the dealer next week. All of the dealers around hear have special water techs so the lead time is much longer for an appointment. The one closest to me was Dec 8th and they also gave the heads up that I may get pushed out further.
Can no one make a new truck that keeps water out of the cab?
Cracked and evidence of very minor water intrusion. The crack goes way up, most likely all the way to outside.
This is a very recent development, was fine about a month ago.View attachment 39322
April 2018 build. 21k miles.
Mark, I PMd Ramcares last night. I hope the backorder on rear sliding windows is not as long as Twister is indicating. That is unacceptable, since vehicles are coming off the line each day with new sliding windows.Hi kapinallinen2,
Please let us know if you decide to address this with your Ram dealer. We would like to have this documented and provide you with an additional layer of support for that process.
Hi tonyplants & 2wd,
I'm sorry to hear that you both are experiencing this concern as well. If it would be of interest, I would be happy to escalate cases to get you both connected with a Case Specialist for additional support while working with your dealers. Our team is just a private message away.
Mark
RamCares
