ramButz
i added a "sway bar" a few week ago .i made a little vid.sorry im not much of a "talker"
Just curious, what was it about the Falken tires you did not like? That's the tire I am leaning towards.Bad lighting in 2nd pic but before and after - Falkens to Nittos (285/60R20)View attachment 38773
Check out the Cooper Discoverer AT3 XLTs. Not a better tire on the market right now IMHO. Ran them on my Tundra before trading it on the Ram. Duratracs on the Rebel aren't even close.Just curious, what was it about the Falken tires you did not like? That's the tire I am leaning towards.
What is this vixen horn that you speak of?Installed my new power retraxpro bedcover over my BlueOx Super Ride hitch. Put together Vixen 4 Horn trumpet train Horn, next is the install. Sounds great!! Also need to install the 8 pod Color LED lighting and install the Tazer device To activate auto folding mirrors, flashing light features and many more cool features. Just need time and more daylight.
Not tall or wide enough. Nothing bad about it - just wanted a tire to fill out the wheel well more.Just curious, what was it about the Falken tires you did not like? That's the tire I am leaning towards.
Is there any extra room for a bigger spare or does the 295/60 max out the space?Finally took my rear wheels off and put the last screw in my rear mudflaps. Also got a full-size 20x10 wheel to use as my spare. Test fitted my 295/60R20s under the truck and it fits! Now just need some rubber for it and I’ll be set!
A few dead bodies work well tooAdded (4) 70lb sand tubes to the bed over the rear axle in preparation for winter. The truck feels SO much better with some weight back there. I'll likely run this all year now.
Or a couple fat bottom girls, lolA few dead bodies work well too
So like hornblasters but this is much cheaper seems like. Have you used the vixen ones before?![]()
VIXEN HORNS VXO8115/4124B QUAD TRUMPET TRAIN AIR HORN BLACK WITH 1.5 GALLON TANK AND 150 PSI COMPRESSOR - Vixen Horns
Quad Trumpet Train Air Horn (Black), 150 PSI Air Compressor, 1.5 Gallon Air Tank, Thermal Overload Protection, Electric Air Valve, Pressure Gauge, Pressure Switch, Air Hose, Horn Buttonvixenhorns.com
Most people I know have them in addition to their normal horn, even tying them into their alarm systems.If anyone is interested in those train air horns discussed above, check your local laws first. I do know in some areas they are not legal for use on automobiles. They can be so loud, they can actually create an accident versus helping to prevent one. I watched a video on this years ago. Yes, they sound cool and make a TON of noise, but it can also have the opposite effect of what you are trying to do when using your horn under normal conditions.
That's great but two wrongs don't make a right. Not saying that it is not legal where you may live (your location is incomplete in your profile) but I do know there are areas around the US where they are not from other forums I am a member of where folks have posted similar issues. I am only making the statement to ensure that folks check first BEFORE doing this mod...nothing moreMost people I know have them in addition to their normal horn, even tying them into their alarm systems.
