z0n3
Level and tires.. some of the best money I've spent on her
That looks really sharp. Did you do a self install on the level kit? Change UCAs as well or no?
barakutha
Thanks.. I had the level done at a custom shop for $250. No UCA changes yet
Ellisstrong
Atlanta Ga area
What city was the shop in? I am looking to find a shop in the central Florida area to do this with.
barakutha
Lafayette, LA
I'm sure you'll find a place out there if you ask around
Boa24
Alright i've been searching for the past 2 days and cant find a clear cut answer. In a few weeks i'm ordering the ready lift 2" level and wheels/tires. With a 20x9 and a 285/60 or 285/65. I want them to sit flush with OEM flares. Some pics of 0 offset wheels looked flushed, and so did some with an +18 offset. Which offset will sit flush with the flares?
agjr85
Spring, Tejas
the 18 is practically no change to your stock wheel. You will gain the tire width plus any spacing if going with an aftermarket wheel. Like a 20x10 +18
Go with 0, you'll get the look you want.
U
User_18177
Guest
I'm in the same boat as you. I have the off road package and will be getting the 2" ReadLift with UCA's level. I've done quite a bit of research and will be getting Nitto Ridge Grapplers 285/65R20 and 20X9 with +1 offset wheels (Fuel Warrior) just like Jetisdom. Check out his truck as I think that's what you're trying to achieve as well as myself.
z0n3
I believe I found a good look for trucks without the fender flares that want a slightly aggressive look but not a huge poke of tread outside. Picture below is a 20x9 1 offset with 33”x11.5” Nitto ridge grapplers. Link to more pictures. https://www.customwheeloffset.com/wheel-offset-gallery/717081/2019-ram-1500-fuel-tech-mopar
ryanJ
San Diego
First time poster. Glad to be back in a ram after a couple years in a chevy.
Looking to level by Truck (Ram 4x4 1500 5.7e crew 6.4 bed) At some point ill look into suspension/tires and wheels but for now I purchased the 2" rough country leveling kit (spacers) Read some good reviews but it turns out they were not specific to my application, now i'm a little concerned it will effect the ride quality. Wondering if anyone has any first hand experience with these or has done some research. Thanks
Boa24
thanks I appreciate it
Kevinc13
Quadmafia
2019 Laramie
w/ProRyde Level 74-2000D kit. (Old body style kit for max height gain.
20x9 +12 Hostile Sprocket
295/60R20 Falken Widepeak AT3W
no rub at all no trimming needed.
CusackT
Here is my 2019 2wd big horn quad cab with a 2-2.5 inch motofab strut spacer and 20x9 gmc snowflakes
Alxmlr789
2019 Laramie
Did this add anything in the rear or just the front?
CoachellaValley1500
Just got my new tire/wheel setup installed on my ‘19 Laramie. Super happy with how it turned out. I was thinking of putting a 6 inch lift kit on it, probably rough country or BDS.. but wanted to see it first without. I do have a 2” RC leveling kit on it that’s been on since I got that truck last year.
I’m curious if you all think I should go with the lift, or leave it like it is. Thanks!
3B5932FF-07C3-4C4D-8270-995E4A5DCA8D.jpeg 2A55AC41-A0E3-4531-9599-CD54E75BDFF7.jpeg 8C78D5E1-9F55-4CC9-9D22-3D3681B557FE.jpeg 3112ED47-F28D-4787-9BDB-8197F2E0BB86.jpeg 3C0718B7-5834-459E-A1E6-ADD65408AD57.jpeg 26C92EF9-D6FD-43CD-8728-8E2D4CB4953F.jpeg
Wheels: Dropstars 654mb 20X10 -25 offset
Tires: Federal Xplora MTS 35/12.5R20
Fender Flares: Bushwacker DRT flares.
U
User_18177
Guest
View attachment 38377 View attachment 38376 View attachment 38375 View attachment 38378 View attachment 38379 View attachment 38374
Looks nice, but can you post some pics without those filters?
PorBoy
Millville NJ
^^^. Yes doing so will definitely allow us to truly see what the combo looks like. :)
